Shadow Defender / ShadowFreeze - Wersje stabilne
ShadowFreeze v1.0.6​
[1.0.6] - 2026-10-25​
Added​
  • added tray notifications for background work: progress window near the tray and balloons for failures
  • added commit deletions: commit can now also apply deletes, or deletes only
  • added -commit_path, -events and -jobs to ShadowCli
Fixed​
  • fixed persistence mode checkbox broken with 1.0.5
  • fixed SYSTEM hive corruption when commiting C: after a resume of a persistent frozen state
  • fixed folders moved into an exempt folder coming back as 0-byte files
  • fixed moving a folder tree into an exempt folder only persisting the top folder
  • fixed moves between exempt folders doing a full copy instead of a rename
  • fixed large copies into an exempt folder stalling at 99%
  • fixed opening a large file in an exempt folder taking seconds every time (right-click, cut, thumbnails)
  • fixed a folder marked exempt shortly before freezing not being protected at all
  • copying into an exempt folder is now much faster and barely uses the shadow storage
  • fixed a folder moved into an exempt folder on exFAT being lost on revert
  • moving or deleting a large file out of an exempt folder is no longer slow
  • fixed the system becoming unresponsive while a large folder was copied into an exempt folder
  • fixed the progress window appearing at the wrong screen corner instead of next to the tray
  • fixed the progress window layout: mismatched background and a large empty area below the bar
