Sweet Home 3D - aranżacja wnętrz
Sweet Home 3D 7.0
Changes in Sweet Home 3D 7.0 (July 13, 2022):
  • Added YafaRay rendering engine with the ability to choose the rendering engine in photo and video creation tools at the two best quality levels (not available for Java Web Start and applets).
  • Added lightSourceMaterialName# property to define materials of a 3D model used as light sources (with light color deduced from material color and the ability to create an invisible light source when its material is invisible).
  • Allowed decimals in Light power spinner.
  • Made the dialog boxes of photo and video creation tools resizable.
  • Displayed the virtual visitor with a camera symbol at a fixed size when the virtual visitor gets too small in the plan.
  • Added a button in the toolbar to enable/disable magnetism.
  • Moved menu items handling levels in the Levels submenu to reduce Plan menu length.
  • Added the ability to select materials with the mouse in the 3D preview in Material modification dialog box.
  • Added diagonal editing in the room creation tool tip to draw rooms by triangulation.
  • Added Inch/Fraction unit which displays lengths in inches followed by the closest eighth inch fraction.
  • Added Foot/Decimals unit which displays lengths in feet followed by decimals of a foot.
  • Added Hide model edges option at second step of Furniture import wizard to hide easily edges of 3D models at DAE / Collada format (option displayed only when useful).
  • Handled more orientation and zoom capabilities on 3D models at last step of Furniture import wizard to get better icons.
  • Added new prefixes for shape names of a 3D model to specify the possible moves of shapes attached to other movable shapes.
  • Computed the front limit of the 3D view frustrum according to the point of view elevation to improve the rendering of very large scenes seen from a high point of view.
  • Added sky image mirror at bottom of background image to avoid possible line at the horizon in renderings at best quality levels.
  • Added Flat ceiling only check box to room modification pane to compute sloping ceilings when necessary.
  • Added com.eteks.sweethome3d.checkUpdates system property and /checkUpdatesDisabled argument to Windows installer to prevent following updates.
  • Increased the divider size of split panes under Windows.
  • Fixed room floors and ceilings drawing order.
  • Added the ability to display animated GIF icons in catalog tool tips.
  • Fixed nodes hierarchy in 3DS format management.
  • Fixed default color of effect in DAE format.
  • Added support for controller / skin elements in DAE format to be able to import 3D models exported from MakeHuman software.
  • Fixed too small fonts under Windows 11 with a HiDPI screen.
  • Handled the user interface of 3D model transformations in Sweet Home 3D JS Online.
  • Updated Italian translation including help by Vincenzo Reale.
  • Other minor bugs fixes and enhancements.
Sweet Home 3D 7.1
Changes in Sweet Home 3D 7.1 (March 3, 2023):​
  • Added furniture description field in Sweet Home 3D and the Furniture Library Editor.
  • Added the description of a piece of furniture set in a SH3F file to the catalog furniture tool tip.
  • Updated Java 3D 1.6.2 to avoid corrupted 3D view and furniture icons with recent AMD Adrenalin driver versions under Windows.
  • Updated JOGL to version 2.4.0-rc-20221118 to fix a hanging issue in the furniture import wizard under macOS.
  • Ignored auto completion at initialization time of text fields.
  • Fixed handling of delete keys when catalog search text field has focus in the Sweet Home 3D JS Online.
  • Added Portuguese from Portugal translation as default Portuguese translation and made Portuguese translation of previous versions as Brazilian Portuguese translation.
  • Made JAR executable version of Sweet Home 3D, Furniture Library Editor and Textures Library Editor able to be launched with a double-click under Java version ≥ 16.
  • Fixed computed limit between joined walls of different thicknesses.
  • Updated Azul OpenJDK runtime bundled in Sweet Home 3D installer with Azul OpenJDK 11.0.18 under Windows 64 bit and Azul OpenJDK 15.0.10 under Mac OS X ≥ 10.9.
Sweet Home 3D 7.3​
Apr 4, 2024
  • Added up and down arrows to scroll the Go to point of view menu when it's too long on small screens.
  • Fixed mirroring operation on a group of furniture containing rotated pieces.
  • Prevented fixed parts in mirrored pieces from moving after an horizontal deformation.
  • Allowed importing 3D models with missing deformation groups.
  • Fixed the font of dimensions in the 3D view to the one set in preferences.
  • Fixed a regression where imported 3D models were added to the furniture catalog even if not requested.
  • Fixed sort on levels with an elevation index in the furniture table.
  • Fixed file dialog box display in Windows environments with special homonyms.
  • Fixed the printed level name in header and/or footer of the pages showing the plan.
  • Placed menu items of untranslated plug-ins in existing known menus.
  • Ignored installed plug-ins not compatible with the running Java version at program launch.
  • Added category and multiple words search capability in the furniture catalog of Sweet Home 3D JS Online.
  • Fixed sort on model size in Furniture Library Editor.
  • Removed macOS support from portable version because recent macOS versions refuse to write in data folder for security reasons.
  • Updated German help pages by Waldemar Hersacher.
Sweet Home 3D 7.5​
Version 7.5, August 21, 2024​
  • Fixed synchronization issues on the 3D view when displayed in a separate window.
  • Fixed 3D view rendering of underground levels at same elevation.
  • Fixed font display in Thai user interface.
  • Fixed default value of doorOrWindowWallThickness# property and saving of lightSourceMaterialName# property containing commas in
  • Changed copyright notices after Space Mushrooms taking over Sweet Home 3D project.
