Tabbles for Small Groups za darmo
Tabbles for
Wersja dla GAOTD
Tabbles for Small Groups pozwala oznaczyć pliki, wiadomości e-mail (w programie Outlook) oraz zakładki w taki sposób, aby je później szybko odnaleźć. Pomaga je zorganizować w sposób niezależny od folderów. Program łączy znaczniki za pomocą kilku kliknięć myszką, dzięki czemu można natychmiast odnaleźć plik na dysku...
Using Tabbles you can categorize your files, folders or internet addresses by cross-linking them to one or more tabbles. A tabble is a visual tag that behaves like a virtual folder.
Since Tabbles is a desktop application, it's well integrated into the Microsoft Windows environment: categorization can be done using the usual explorer functions, such as copy-and-paste, drag-and-drop (keyboard shortcuts and right-button menu included) or using the buttons on the tabble's.
Please note: Tabbles for Small Groups is a special build developed specificaly for Giveaway of the Day users and it slightly differs from the Home version:
Visual Tagging: Unlimited
Explorer Integration: +
Outlook Integration: +
Access your tagging from several PCs: -
Cloud Synchronization tagging: - (“LocalDB” and the “LAN” mode)
Tag sharing: Up to 3 users (one user per license)
Comparison with other versions is available
