Xvirus System Cleaner Pro v3.0.0.0
Instalacja i aktywacja
.Xvirus System Cleaner Pro czyści, konserwuje i optymalizuje system operacyjny..
Xvirus System Cleaner Pro is a capable application designed to help you keep your computer clean and optimize its performance. Moreover, you can fix registry entries, defragment disks and remove unnecessary, junk files. You can clear cookies, cache, history and temporary Internet files, in order to protect your online privacy.
Features
Clean your pc with just one click
Tweak your pc in order to make it faster
Easy to use and light
Privacy Shield
Automatic scan
