Re: Easy CD-DA Extractor
Easy CD-DA Extractor 2011.3
Version 2011.3
Fixed the bug where data error was shown when ripping the last track even there was no actual data error
Fixed the bug where <Total Discs> and <Disc Number> symbols in Output Filename field was not loaded correctly from a profile when other than english-language was in use
Fixed the bug where mono input files were encoded to MP3 at double speed because MP3 encoder was always expecting stereo samples
Fixed the bug where cursor was not visible in the list editors when other than 96 dpi display mode (Windows large fonts) was enabled
Fixed the bug where some multi-language user interface components were translated wrong
Fixed the bug where some encoders, decoders, and metadata handlers were compiled with debugging info enabled -> performance improvements !
Added Play in default player on-double click feature (Audio Converter, Metadata Editor, Audio CD Burner, MP3 CD Burner)
Adjusted some user interface components default size and positions
Updated FLAC encoder, decoder, and metadata handler; compiled with the latest Ogg library v1.2.2
Updated Ogg Vorbis encoder, decoder, and metadata handler; compiled with the latest Vorbis library v1.3.2 and the latest Ogg library v1.2.2
Updated Monkey's Audio encoder, decoder, and metadata handler; compiled with the latest Monkey's Audio SDK 4.11
Re-compiled all encoders and decoders with SSE and SSE2 instruction sets enabled -> performance improvements !
Easy CD-DA Extractor 15
Changes in 15:
MusicBrainz now gets correct metadata for subsequent discs of multi-disc releases
ID3V2 character encoding (Unicode/UTF/Ansi) setting now works
New output filename template handling
Silence removal DSP now removes analog silence
Optimized all encoders and decoders with SSE/SSE2/SSE3 instruction sets enabled and added backward compatible codepath for old processors that do not support SSE/SSE2/SSE3 multimedia instructions
Easy CD-DA Extractor 15.1
Changes in 15.1:
Now works again with all processors (v2011.3 and v15.0 required a processor with SSE2 instruction set)
Re-compiled and re-optimized all codecs with Intel to take performance benefits from processors with SSE, SSE2, SSE3, SSSE3, SSE4.1, and SSE4.2 multimedia instruction sets
Fixed a bug where removal of all metadata from ID3V2 tag did not work
Empty album artist is no longer set to track artist in Audio Converter / Metadata Editor
Fixed shell extensions (bug was added in v15.0)
Fixed freedb server list from options (bug was added in v15.0)
hubiX
16 Wrzesień 2010
:D Super program do edycji i rippowania płyt. :D Może konkursik
Easy CD-DA Extractor 15.3.0.1
Changes in 15.3.0.1:
New Dolby Pulse AAC / HE AAC encoder !
LAME 3.99 MP3 encoder
Automatic ReplayGain calculation
ReplayGain "2.0": Original ReplayGain algorithm replaced with ITU-R BS.1770 (new standard, more accurate, faster)
Ogg Vorbis codec improved and updated
Internal sample rate converter set to highest quality mode
Changes in Audio Converter internal behavior, making it faster in certain conditions
Fixed AAC/HE AAC encoding problem in multi thread Audio Converter
Updated Amazon Cover Art Search protocol to the latest version (old version will stop working on Feb 2012)
Easy CD-DA Extractor 15.3.2.1
Changes in 15.3.2.1:
New Apple Lossless encoder by Apple.
Improved compression and 24-bit support.
Fixed the bug where the program wouldn't start with oldprocessors that don't have SSE multimedia instructions.
