- Dołączył
- 4 Czerwiec 2013
- Posty
- 7200
- Reakcje/Polubienia
- 47
Re: Easy CD-DA Extractor
EZ CD Audio Converter
EZ CD Audio Converter Free 2.2.2
EZ CD Audio Converter Ultimate 2.2.2
2.2.2
Improved the shell folder view
Updated Simplified Chinese, Polish, Greek, Spanish, and Catalan language files
2.2.1
Fix for the "file read error" in Audio CD burning with v2.2.0 (debug mode was enabled) Ooops
Updated Dutch, Italian, Japanese, Estonian, Slovenian, French, Russian, and German language files
2.2
User interface improvements:
Improved manual entering of disc information
Improved visuality
ID3V2 comment field bug fixed (was truncated to 128 characters when 'Save Metadata' to source file was used)
Conversion from FLV, wrong playback speed problem fixed
File format options:
Compatibility format for WAV (some old programs expect certain order of WAV/RIFF headers)
Settings for MP3, AAC ID3V2 gapless playback information
Settings for M4A/AAC/HEAAC gapless playback information
New Shell Browser component (bugs fixed)
2.1.7
More AAC VBR quality options, now 1-8, added higher bitrate VBR encoding
Fixed a bug in AAC LC format detector (showed sample rates <= 24000 wrong)
2.1.6
New AAC encoder (FhG FDK AAC)
Variable Bitrate (VBR) encoding for AAC
2.1.5
Added MP3 compressed WAV output format (per user requests)
Bugfix for compressed WAV decoder
2.1.4
New multilanguage installer
Language updates
Improved AAC format detection, mono AAC is now converted to mono
Bugfix: Ripping to Ogg Vorbis now works in 32-bit version
2.1.3
Improved Internet metadata download (possible to request all services simultaneously)
Internet metadata download in Audio Converter (can retrieve metadata for files)
MusicBrainz service updated; more accurate results
Cover art download from MusicBrainz service
Cover art can be resized
2.1.2
Bug fix for sample rate converter (updated in v2.1.0). Insufficient sample rate conversion buffer caused program to crash in the end of a track ripping or file conversion under certain circumstances.
2.1.1
Ripping log
2.1
Gapless support for .m4a/AAC (iPhone/iPad/iPod compatible)
Gapless support for .aac/AAC
Improved gapless support for .mp3 (now iPhone/iPad/iPod compatible)
Gapless sample rate converter
All FLAC compression levels are included
More information about the audio files in Audio Converter (length in ms, gapless, format, samples)
Track number in Audio CD Burner
Can change track numbers in Audio CD Ripper
UPPERCASE/lowercase/Sentence case/Title Case for Audio Converter & Audio CD Burner
Other minor user interface improvements
Bugfix: Gapless bugfix for Opus encoder
Bugfix: Read Year-tag from ID3V2.4
2.0.7
M4A format reading and writing performance significantly improved
Fixed a multithread deadlock bug in treeview ui component:
Has caused file conversion to freeze (that was seen when converting large amount of files at once)
Possibly has caused random freezing of the user interface
2.0.6
WavPack metadata reader now works with old processors (without SSE)
Paste cover art in Audio Converter's popup-menu now enabled as it should have been
2.0.5
Vorbis 1.3.4 codec
Bugfix for MP3 header detection (sometimes wrong sample rate was detected, resulting in wrong playback rate when converted from MP3)
New Windows Explorer view controls (bugs fixed)
Minor change in Audio Converter cover art box (multi-selection of different images now alphablended)
Updated language files
2.0.4
Fixed a bug that caused program to crash when adding files/folders to MP3 disc and Data disc layouts
2.0.3
Fixed a bug in Joliet filesystem (MP3 CD and Data CD)
2.0.2
Fixed drag n drop bug in Disc Burner (64-bit)
Improved user interface scaling on high DPI screen modes
2.0.1
Burning speed selection fixed
Language file updates
2.0
UI refresh
Opus 1.1 codec update
Save files to ISO image in Disc Burner
Improvements to overall quality
1.3.4
Wavpack 4.70.0 codec update
Updated Windows Explorer style components (bugs fixed)
Added drive letters for easier identifying of drives
1.3.3
Certified for Windows 8.1
Support for converting audio from WebM videos
Bugfix for handling very long file paths
Bugfix for reading pre-defined genres from M4A files
1.3.2
New Apple Lossless decoder. Better handling of corrupt ALAC files. Faster.
M4A format metadata (Rating, Publisher, URL) now compatible with Windows Explorer & Windows Media Player
1.3.1
Bug fix for the mistake where Audio Converter's 'Single File' mode was always enabled
1.3
Monkey's Audio 4.12 codec
Opus 1.0.3 codec
Single File mode in Audio Converter (combine multiple files into one)
Support for 64-bit WAV (RF64)
Allow ReplayGain calculation in Single File output modes
Bugfix for ripper not showing the number of failed tracks
Can update metadata of >2GB .MP3 and .AAC files
Can convert from >2GB .MP3 and .AAC files
Opus format improvements (faster loading, album gain)
1.2.5
Apple Lossless (ALAC) encoder fixed
Audio Converter no longer crashes with long output paths
Amazon Cover Art now works in Japanese (and other non-Latin languages)
WMA decoder now correctly supports high-resolution multichannel audio
Updated swedish language
1.2.3
Fixed the bug where cover art was not read from FLAC files in Audio Converter (got broken in v1.2.1 update)
Updated russian language
1.2.2
Changed Cover Art / Paste function to get JPEG (rather than PNG) format from Clipboard and Internet Explorer
Fixed the bug in 64-bit version where doing drag 'n' drop in Disc Burner crashed the program
Updated finnish, japanese, and slovak languages
1.2.1
Updated FLAC codec (FLAC 1.3.0 & LibOgg 1.3.1)
Updated Opus codec (LibOgg 1.3.1)
Updated Ogg Vorbis codec (LibOgg 1.3.1)
Fixed metadata-panel wrong font problem in Windows XP
Updated romanian, german, greek, italian, korean, polish, and french languages
1.2
Updated Dolby AAC / HE AAC / Pulse encoder
1.1
Improved support for converting audio from video files
Improved multichannel downmixing
General performance improvements
1.0.8
Fixed the problem where freedb query not populating Artist/Album field correctly
Updated shell extensions
Updated shell browser components
1.0.7
Fixed minor issues in 64-bit version
1.0.6
Fixed the bug where 64-bit version crashed in conversion when ReplayGain was enabled
1.0.5
64-bit version
1.0.4
Fixed the bug where the file conversion would halt if there were folders in the list, all items were selected and 'Remove converted files from the list' option was enabled
Corrected wrong font in folder-view when Windows Large Fonts setting was enabled
1.0.3
Enabled Make Disc Image feature that got accidentally disabled by previous updates
Enabled on-click quick edit mode for track & file lists
1.0.2
Opus Codec 1.0.2 update
User interface tuning
1.0.1
Fixed wrong font of metadata fields in Windows XP
Fixed Metadata Editor / Rename files function
1.0.0
Initial release based on Easy CD-DA Extractor
Program name change from Easy CD-DA Extractor to EZ CD Audio Converter
New user interface
Improved audio quality
Opus audio codec
Faster startup time
