FanControl V90
Move graph points horizontally
Update LHM: Improved AMD GPU support
Assisted setup: helps you configure for the first time
September 22, 2021
- Horizontal UI option
- Fixed graph bug (#335)
- Updated LibreHardwareMonitorLib (driver)
- New sensor settings dialog window
- Refined fan start and stop logic
- Subtract function for mixes
- Fix storage sensor enabling/disabling bug
- Sensor settings no longer overwrites your config when making a change
- Refined assisted setup
- Fixed bug with start/stop detection
- UI refinements
January 5, 2022
- Cute spinning fan icon
- Auto fan-curve (BETA): Changed parameters names to better reflect their usage.
- Bug fixes
- Bug fix with serialization when no config is yet saved.
- Bug fix with numeric up down fields
February 17, 2022
March 3, 2022
- Nickname any temperature sensor from the sensor settings dialog
- Fixed a graph display bug in the graph fan curve card
New
- Configurable temperature range for graphs
- Better decimal support in graphs
- Auto fan curve (BETA): Automatically adjust speed to keep target temperature
- Allow text-wrapping for long names
- Sensor settings dialog window. Activate or deactivate specific sources.
- Numeric textbox for graph points
