FanControl V130
New
  • (NEW) Opt-out of update popup for a specific version
  • Configurable temperature range for graphs
  • Decimal support in graphs
  • Nickname any temperature sensor from the sensor settings dialog
  • Auto fan curve (BETA): Automatically adjust speed to keep target temperature
FanControl 136
New
  • (NEW) Use the -c or --config [json config file] command line argument while the app is open to switch config. Create shortcuts with predefined configs.
  • (NEW) When the app fail to start due to sensor initialization issue, the sensor settings window will open
  • (NEW) Refined UI
  • 0 RPM override for Nvidia cards
FanControl V137
New
  • (NEW) Refined UI
FanControl V138
  • (NEW) Minimum % on control cards
  • Use the -c or --config [json config file] command line argument while the app is open to switch config. Create shortcuts with predefined configs.
  • When the app fail to start due to sensor initialization issue, the sensor settings window will open
  • Refined UI
