FanControl V110
April 5, 2022
- Configurable temperature range for graphs
- Better decimal temp support
- Fixed a bug where the graph width was changing dynamically
April 5, 2022
New
- Decimal support in graphs
- Nickname any temperature sensor from the sensor settings dialog
- Auto fan curve (BETA): Automatically adjust speed to keep target temperature
- Sensor settings dialog window. Activate or deactivate specific sources.
New
New
May 16, 2022
- Change tray icon color from "Theme and colors" dialog
- Fixed a bug when matching a single fan automatically
- Fixed various issues with dialogs
- (NEW) Opt-out of update popup for a specific version
May 31, 2022
- Fixed cache being flushed randomly on shutdown
- Tweaked the auto fan curve
- Improved the assisted setup for faster stop% step
June 9, 2022
- UI improvement: better use of the accent color
- More robust wake from sleep
- Fixed a bug when editing a graph
- Assisted setup: New settings step + faster fan pairing
- Starting the app twice will open back the existing instance
- UI refinements
- Updated LibreHardwareMonitorLib
July 16, 2022
- Various bug fixes
August 1, 2022
- Various bug fixes
- Fixed a drag and drop issue removing user selection
- More robust retry logic when the app starts (requires to re-save your config)
- The app will now save the number of detected sensors in your config. At boot, if the number of sensors is different than the one saved in your config, the app will refresh a few times until the number of sensors matches.
- Bugfix: Start% issue with non-stopping fans
- Bugfix: Sensors were not refreshed when changing config
- Bugfix: Nicknames were not saved properly
- Add scrollbar to message dialog
- .NET 6.0 version available
- Bugfix: Plugin initialization would duplicate cards
- Update LibreHardwareMonitorLib (NZXT GRID+ V3 support)
