Tails - system do zadań specjalnych
Tails 4.15.1
This release is an emergency release to fix a security vulnerability in sudo.
You should upgrade as soon as possible.
Changes and updates
Included software
  • Update sudo to 1.8.27-1+deb10u2, which fixes CVE-2021-3156, a major vulnerability that allows normal users to gain root privileges.
Tails 4.22
Changes and updates
Included software and hardware support
Tor Connection
  • Change the custom bridge interface to only allow entering 1 bridge. (
    People had troubles knowing how to enter their custom bridges when the widget was a textarea and only the first bridge is used anyway.
