Tails - system do zadań specjalnych
Tails 5.6
Changes and updates
  • Update Tor Browser to
  • Update the Linux kernel to 5.10.149. This should improve the support for newer hardware: graphics, Wi-Fi, and so on.
Fixed problems
  • When a manual upgrade is required, Tails now always points to the release notes of the latest version, instead of pointing sometimes to a deprecated version. (
Tails 5.8
Tails 5.8 is the most important release of Tails in years. It includes both major redesign of existing features, important usability improvements, and hardened security.
This work has been made possible by donations from users like you. If you like these changes and want more, donate now to fund our work in 2023.
New features​
New Persistent Storage​
After 2 years of hard work, we are extremelly proud to present you a complete redesign of the Persistent Storage.
The Persistent Storage hasn't changed much since its first release in 2012 because the code was hard to modify and improve. But, we learned from users that the Persistent Storage could do a lot more for you if it had more features and was easier to use.
  • You don't have to restart anymore after creating the Persistent Storage or each time you activate a new feature.
  • You can change the password of your Persistent Storage from this new application.
  • You can choose to create a Persistent Storage directly from the Welcome Screen, if you don't have one already.
Wayland and better Unsafe Browser​
We replaced the deprecated X.Org display system with Wayland.
Even if you won't notice any visual difference, Wayland brings more security in depth to Tails by making it harder for a compromised application in Tails to compromise or misuse another application.
For example, since
, the Unsafe Browser was disabled by default because a security vulnerability in another application in Tails could start an invisible Unsafe Browser, reveal your IP address, and
Wayland fixes this vulnerability and makes it safe to reenable the Unsafe Browser by default. You can still disable the Unsafe Browser in the Welcome Screen.
Wayland also brings in other features that were not working yet in the Unsafe Browser:
  • Sound
  • Uploads and downloads
  • Alternative input methods for Chinese and other non-Latin languages
  • Accessibility features like the screen reader and virtual keyboard
QR code scanning of Tor bridges​
We made it easier to enter new Tor bridges in Tails by scanning a QR code.
To get a QR code, you can either:
We are aware that the QR codes that are currently provided are too big to be easy to scan. We are
to make them smaller and easier to scan.
Changes and updates​
Fixed problems​
We fixed 3 usability issues in the Tor Connection assistant:
For more details, read our
Tails 5.9
Tails 5.9 is out 2023-01-23
We are sorry that Tails 5.8 affected many of you so badly.
Thanks to your patience and feedback, we were able to solve most of these new issues.
Changes and updates
  • Update the Tor client to 0.4.7.13.
  • Simplify the error screen of the Tor Connection assistant when connecting automatically.
  • Improve the wording of the backup utility for the Persistent Storage.
  • Remove the confirmation dialog when starting the Unsafe Browser.
Fixed problems
  • Fix support for some graphics cards:
    • Update the Linux kernel to 6.0.12. This improves the support for newer hardware in general: graphics, Wi-Fi, and so on. (
    • Remove from the Troubleshooting Mode 2 boot options that break support for some graphics cards: nomodeset and vga=normal. (
      Please let us know if the support for your graphics cards has been fixed or is still broken.
  • Fix starting AppImages that use the Qt toolkit like Feather and Bitcoin-Qt. (
  • Fix clipboard encryption and decryption in Kleopatra. (
  • Fix at least 2 cases of Persistent Storage not activating:
    • When activation takes longer (
    • When the Dotfiles feature includes symbolic links (
      Please keep reporting issues with the new Persistent Storage. We give them top priority!
  • Fix 3 clipboard operations with KeePassXC:
  • Fix the display of the applications menu that was broken in some GTK3 applications installed as Additional Software. (
  • Localize the homepage of Tor Browser when started from the Tor Connection assistant. (
Known issues
Please keep reporting issues with the new Persistent Storage and when starting on graphics cards that used to work with Tails.
Tor Browser has no minimize and maximize buttons (
To work around this:
  1. Right-click on the Tor Browser tab in the window list at the bottom of the screen.
  2. Choose Minimize or Maximize.
Welcome Screen and Tor Connection don't fit on 800×600 (
The top of the Welcome Screen and some button of the Tor Connection assistant are cut out on small displays (800×600), like virtual machines.
You can press Alt+S to start Tails.
Progress bar of Tor Connection gets stuck around 50% (
When using a custom Tor obfs4 bridge, the progress bar of Tor Connection sometimes gets stuck halfway through and becomes extremely slow.
To fix this, you can either:
  • Close and reopen Tor Connection to speed up the initial connection.
  • Try a different obfs4 bridge.
    This issue only affects outdated obfs4 bridges and does not happen with obfs4 bridges that run version 0.0.12 or later.
See the list of
Get Tails 5.9
To upgrade your Tails USB stick and keep your persistent storage
  • Automatic upgrades are available from Tails 5.0 or later to 5.9.
    You can
    of future automatic upgrades by doing a manual upgrade to the latest version.
  • If you cannot do an automatic upgrade or if Tails fails to start after an automatic upgrade, please try to do a
Tails 5.13
New features​
  • Add curl, a command line tool to download over HTTPS, FTP, and other protocols.
    curl can be useful for online investigations as an alternative to wget.
    Everything you do with curl goes through the Tor network. If you want to use curl on a local network, use /usr/bin/curl instead.
  • Use LUKS2 by default for all new Persistent Storage and LUKS encrypted volumes. LUKS2 provide stronger cryptography by default.
    We will provide a migration plan from LUKS1 to LUKS2 for existing Persistent Storage in Tails 5.14 (early June).
Fixed problems​
Known issues​
None specific to this release.
See the list of
