Tails - system do zadań specjalnych
Tails 4.24
Changes and updates
Improvements to the Tor Connection assistant
Fixed problems
For more details, read our
Tails 4.27
Changes and updates​
Fixed problems​
  • Fix connecting to a Wi-Fi network when choosing Open Wi-Fi Settings in the Tor Connection assistant. (
Known issues​
None specific to this release.
See the list of
Tails 5.0
New features​
Kleopatra​
We added
to replace the OpenPGP Applet and the Password and Keys utility, also known as Seahorse.
The OpenPGP Applet was not actively developped anymore and was complicated for us to keep in Tails. The Password and Keys utility was also poorly maintained and Tails users suffered from too many of its issues until now, like
Kleopatra provides equivalent features in a single tool and is more actively developed.
  • The Additional Software feature of the Persistent Storage is enabled by default to make it faster and more robust to configure your first additional software package.
  • You can now use the Activities overview to access your windows and applications. To access the Activities overview, you can either:
    • Click on the Activities button.
    • Throw your mouse pointer to the top-left hot corner.
    • Press the Super (
      ) key on your keyboard.
      You can see your windows and applications in the overview. You can also start typing to search your applications, files, and folders.
Included software​
Most included software has been upgraded in Debian 11, for example:
  • Update Tor Browser to
  • Update GNOME from 3.30 to 3.38, with lots of small improvements to the desktop, the core GNOME utilities, and the locking screen.
  • Update MAT from 0.8 to 0.12, which adds support to clean metadata from SVG, WAV, EPUB, PPM, and Microsoft Office files.
  • Update Audacity from 2.2.2 to 2.4.2.
  • Update Disk Utility from 3.30 to 3.38.
  • Update GIMP from 2.10.8 to 2.10.22.
  • Update Inkscape from 0.92 to 1.0.
  • Update LibreOffice from 6.1 to 7.0.
Hardware support​
  • The new support for driverless printing and scanning in Linux makes it easier to make recent printers and scanners work in Tails.
Fixed problems​
Known issues​
  • Additional Software sometimes doesn't work when restarting for the first time right after creating a Persistent Storage. (
    To solve this, install the same additional software package again after restarting with the Persistent Storage for the first time.
  • Thunderbird displays a popup to choose an application when opening links. (
  • Tails Installer sometimes fails to clone. (
See the list of
Tails 5.3.1
ails 5.3.1 is out 2022-08-02
This release is an emergency release to fix a security vulnerability in the Linux kernel.
Changes and updates
  • Update the Linux kernel to 5.10.127-2, which fixes
    , a vulnerability that allows applications in Tails to gain administration privileges.
    For example, if an attacker was able to exploit other unknown security vulnerabilities in Tor Browser, they might then use CVE-2022-34918 to take full control of your Tails and deanonymize you.
    This attack is very unlikely, but could be performed by a strong attacker, such as a government or a hacking firm. We are not aware of this attack being used in the wild.
  • Update Thunderbird to
Fixed problems
Known issues
See the list of
Tails 5.4
Tails 5.5
    Thunderbird 102 is a major update with
    Thunderbird 102 also includes important usability improvements to the OpenPGP feature. When composing an email, you can now see whether it will be encrypted or not. If encryption is impossible, a key assistant helps you solve key issues.
    Thunderbird composer window with encryption turned on and notification about a missing key and how to resolve the issue.
  • Update the Linux kernel to 5.10.140. This should improve the support for newer hardware: graphics, Wi-Fi, and so on.
  • Make the wget command line utility use a different Tor circuit every time.
Fixed problems​
