Dustbin amp simulator is a free for limited time on Plugin Boutique.
This plugin will litter-ally change your life. Stop wasting time, you can't refuse it any longer. Take everything you thought you knew about music production and throw it out.
Pick your way through the impulse responses taken from the Bin's cavity and built-in speaker. Transform your Garage into Garbage, Rap into Scrap, Pop into Slop, Punk into Junk, and New Age into Sewage.
No more worrying about if your music sounds trash, now it definitely does. You're welcome.
It is a bin (trashcan for our US friends).
Impulse responses from multiple microphones in multiple positions.
Make your tracks sound like they are inside a bin.
System Requirements:
Windows
- Windows 7 or higher
- VST3 and AAX (AAX is 64 bit only)
Mac
- macOS 10.11 or higher (64 bit only)
- AU, VST3, and AAX
- Native Apple Silicon support
Windows
Mac
- AU, VST3, and AAX
