EZ CD Audio Converter 3.0.1.1
Audio CD Ripper: CTRL+A now selects all tracks for metadata editing
Installer: Auto-close software before installing, don't proceed with the installation if the EZ CD is still running
Bugfix: Audio CD Ripper - Metadata edit fields were not resized correctly in metadata left/right mode when the metadata panel was resized
Bugfix: Audio CD Ripper - Correctly detects and fixes invalid start time for the first track (very rare CDs with invalid TOC)
Bugfix: Fixed the problem where program crashed when the Main window was closed while Converter or Ripper window was still open
Language updates: French, Italian, German, Polish, Romanian, Hungarian
EZ CD Audio Converter Free 3.0.1.1
EZ CD Audio Converter Ultimate 3.0.1.1
EZ CD Audio Converter 3.0.2.1
Improved user interface scaling with Windows large fonts / upscaling
Bugfix: Fixed small black marks in the user interface that appeared with some display drivers
Bugfix: Fixed auto read CD-Text not setting the Album Artist and Album field
Language updates: Japanese
EZ CD Audio Converter Free 3.0.2.1
EZ CD Audio Converter Ultimate 3.0.2.1
EZ CD Audio Converter 3.0.3.1
Updated AAC encoders
As Dolby discontinued Dolby Pulse format, it's now removed, but added is the high quality Dolby AAC / HE AAC encoder. Dolby AAC / HE AAC encoder provides the best low bitrate audio quality for HE AAC v1/v2
Automatic update check setting is now correctly saved in Settings
Copy to clipboard functionality in Audio CD Ripper restored
Language updates: Spanish, Turkish
EZ CD Audio Converter Free 3.0.3.1
EZ CD Audio Converter Ultimate 3.0.3.1
EZ CD Audio Converter 3.0.3.2
Fixed .aac and .m4b Dolby AAC formats (by adding the two DLLs that should have been included with the original v3.0.3 installer).
Language updates: Dutch
EZ CD Audio Converter Free 3.0.3.2
EZ CD Audio Converter Ultimate 3.0.3.2
EZ CD Audio Converter 3.0.4.1
Updated device access layer, improved performance
Fixed .aac and .m4b Dolby AAC formats (by adding the two DLLs that should have been included with the v3.0.3 installer)
Language updates: German, Dutch, Romanian
EZ CD Audio Converter Free 3.0.4.1
EZ CD Audio Converter Ultimate 3.0.4.1
EZ CD Audio Converter 3.0.5.1
Fixed the problem where Windows XP did not have the dropdown menus for metadata, rip, and convert buttons
Improved device access layer performance (removed unnecessary thread synchronization objects and performed optimizations)
Faster Pre-Gaps, ISRC, Pre-Emphasis detection
Faster CD ripping
Faster disc burning
Faster multithreaded audio file format conversion
General multithread performance improvements
Improved CD ripping begin speed (drive will immediately accelerate to the desired speed, device dependent)
Composer fields are now saved/loaded to/from the local database
Language updates: Italian, Hungarian, Greek
EZ CD Audio Converter 3.0.6.1
Very Important Bugfix: Bug in CD-DA read cache buffer in v3.0.5 fixed. Symptom was garbled audio in ripped audio files. It was a human error, using wrong type of synchronization method with the cache buffer.
Language updates: Russian
EZ CD Audio Converter Free 3.0.6.1
EZ CD Audio Converter Ultimate 3.0.6.1
EZ CD Audio Converter 3.0.7.1
Shell folder view is now auto-refreshed correctly (when folder/file rename/delete/move happens)
Shell folder and file views now correctly support F2 shortcut button for renaming a file/folder
Performance improvements for shell views
Added cover art resize to 600x600
Language updates: Estonian, Korean
EZ CD Audio Converter Free 3.0.7.1
EZ CD Audio Converter Ultimate 3.0.7.1
helium
16 Czerwiec 2010
helium
16 Czerwiec 2010
EZ CD Audio Converter 3.0.8 build 2 (9 July 2015)
- File shell list view bug fix revisited - improved the auto-refresh function
- File shell list view now remembers the width of the filename field in details-mode
- Language updates: Italian
helium
16 Czerwiec 2010
helium
16 Czerwiec 2010
EZ CD Audio Converter 3.1 (12 July 2015)
- Fixed the "Out of range" error that occured on startup/shutdown when Windows Explorer style controls were hidden
- Fixed the file list view "list" mode filename field autosizing
- Fixed the tab order of action buttons
- Language updates: Korean, Romanian
helium
16 Czerwiec 2010
EZ CD Audio Converter 3.1.1 (01.09.2015)
- File paths are no longer limited to 260 characters (old Windows MAX_PATH limit). Long file paths up to 32767 characters are now supported.
- Vorbis codec updated to v1.3.5
- WavPack codec updated to v4.75.0
- Fixed memory access bug in metadata query (may have caused freeze or crash during metadata query)
- Freedb disc database entries that have " - " separator in all freedb titles are no longer detected as compilation discs and therefore are correctly read from the freedb database
- Local disc database entries that have " - " separator in all track title fields are no longer detected as compilation discs and therefore are correctly read from the local database
- Disc Number, Total Discs, Publisher, Compilation metadatas are now correctly assigned when single file + cue sheet is added to the audio converter
- Year metadata is now read from ID3V2.4 (UTF8) tagged WAV and AIFF files
- Improved Windows DPI awareness, no longer blurred text when Windows DPI scaling is in use
