helium
16 Czerwiec 2010
helium
16 Czerwiec 2010
EZ CD Audio Converter 3.1.3.1 (30 Oct 2015)
Updated Windows Explorer components
· Improved Windows 10 support
· Improved Windows 8, 7, Vista, XP shell folder layout
· Support for network browse, drag n drop files from network
Support for conversion from fragmented M4A/AAC files
Improved user interface layout
Improved user interface icons
Improved Audio CD Ripper's CD player
EZ CD Audio Converter Free
EZ CD Audio Converter Ultimate
helium
16 Czerwiec 2010
EZ CD Audio Converter 3.1.5 (09 Dec 2015)
Opus Codec v1.1.1
General performance improvements
Minor user interface improvements
French, Italian, Turkish language updates
EZ CD Audio Converter 3.1.6
Bugfix: Drive Spin Up now working definitely
Read CD-Text character conversion to Unicode, so non-latin CD-Text is displayed correctly (e.g. Greek, Japan, Chinese, Russian)
Read TOTALTRACKS / TOTALDISCS metadata if the standard TRACKTOTAL / DISCTOTAL does not exist (FLAC, Opus, Vorbis)
Improved Audio Converter logic on Overwrite / Skip existing files
Software is now signed with SHA-256 algorithm for enhanced security
Finnish, Spanish, Portugues, Japanese, Hungarian, Polish language updates
helium
16 Czerwiec 2010
EZ CD Audio Converter 3.1.7.1 (20 Jan 2016)
- Bugfix: Fixed the Internet metadata query, that got broken in the previous update (32-bit version only, C++ compiler bug)
helium
16 Czerwiec 2010
EZ CD Audio Converter 4.0.0 (14 Apr 2016)
Improved metadata support
49 predefined metadata fields, see metadata list and mappings
Custom metadata fields
20 picture types
Support for multiple pictures
All metadata and pictures are transferred on format to format conversion
New metadata editor window that allows 'all metadata' editing
Possible to set different metadata values for each track in Audio CD Ripper (e.g. Comment, Cover Art, WWW an be different for each track)
New local disc database
All metadata, all pictures, are saved
Backward (read) compatible with the old local database
Improved picture handling
Faster thumbnail generation
Less memory usage
Lossless JPEG rotation
Opus Codec v1.1.2
Default ID3V2 tag is now set to ID3V2.3 Unicode
Few user interface improvements
ToGor
Easy CD-DA Extractor to był jeden z moich ulubionych programów, niestety - po zmianie nazwy - zmieniono też cenę ... 40€ za konwerter ... Chyba przesadzili ... Nic dziwnego, że nie mają chyba zbyt wielu klientów ... Szkoda ... Gadać też ... :ireful
Choć program dopracowany ... :scratch
Trudno - będzie inny - darmo /albo taniej/, ale legalnie ...
artoor
6 Lipiec 2012
Częstochowa
Zachęcam do przyjrzenia się bliżej temu programowi. Ośmielam się sądzić, że EAC w niczym nie ustępuje EZ CD Audio Converter. Po dobrym skonfigurowaniu można wycisnąć z przegrywanych płytek na prawdę wiele.
helium
16 Czerwiec 2010
EZ CD Audio Converter oraz EAC to dwa różne programy chociaż funkcję zgrywania CD posiadają obydwa. EAC to mój podstawowy soft do zgrywania CD bo tylko on jest uznawany przez ludzi znających się na rzeczy. Tworzy Log zgrywanej płytki CD i ktoś kto ma pojęcie może z niego wszystko wyczytać (parametry ustawień oraz przebieg zgrywania CD). EZ CD Audio Converter także ma funkcję tworzenia Logu zgrywanej płytki CD ale na żadnym forum poświęconym muzyce Lossless nie cieszy się uznaniem. Jest to raczej soft dla amatorów i służący głównie do konwersji między formatami muzycznymi. Dawno temu kupiłem licencję, wtedy jeszcze chyba za 29$ i prawdę mówiąc nie używam tego programu od dawien dawna. Apropos licencji to zezwala ona na instalację na wszystkich domowych komputerach.
One license allows product use on all of your home PCs
ToGor
Cóż - bardzo dziękuję ... EAC ... Pamiętam ... Trochę mi nie leżał, ale już nawet nie pamiętam czemu ... Ludzie "starej daty" tak czasem mają ... Ja tak mam ... Przywykłem, ba - nawet na Win 7 /x32/ używałem starego Easy CD-DA Extractor-a z jakiegoś promo w prasie, pod x 64 kiepiło, to teraz "jestem obrażony na Poikosoft", że na konkurs nie chciał mi użyczyć paru licek ... Ciągle liczę, że może w końcu ktoś "z Naszych" go spyta najpierw czy ma dobry humor, a jak nie to może napiszemy innym razem ;)
Wiecie - to jak z miłością życia ... Umrze czasem, a każda następna Jej do pięt nie dorasta ... A dotyczy wszystkiego i wszystkich myślę wyborów ... Samo życie czasem boli lub kosztuje - ale uczuć nie kupisz ... No chyba mnie temperatura rozbiera, bo mnie jakoś tak "mieli" dzisiaj ... Dzięki artoor- zerknę jeszcze ... :dziękuję
Zawisza Czarny
22 Lipiec 2010
Trójkąt Bermudzki
Ja nadal używam Easy CD-DA Extractor 2010.6 (zdobyty na naszym forum)
Na Win 8.1 (x64) nie mam z nim problemu. Używam amatorsko głównie zgrywanie z płyt i pedantyczne tagowanie.
Ja prawe też "starej daty" ale młody duchem po prostu lubię ten program od kiedy do poznałem.
Podobała mi się w nim opcja nagrywania z płyty próbek kilkusekndowych. Było to przydatne gdy koledze pomagałem zgrywać kilkaset płyt które były wykorzystywane w radio internetowym. To był okres gdy ten soft zasuwał jak "wół roboczy".
helium
16 Czerwiec 2010
EZ CD Audio Converter 4.0.3 (2 May 2016)
WavPack Codec v4.80.0
Full metadata support for DSF (DSD Stream File)
New DSF (DSD) decoder, with even better accuracy
Automatic Audio CD Ripper's total tracks metadata detection no longer counts data track of an enhanced audio CD
Dutch and Polish language updates
