FanControl V274​
  • Fix a bug where the tray icon would not appear on service start
  • Fix a bug preventing a fan curve to be added into a mix
  • Fix a bug when cancelling a graph edit
  • Tweak control card disabled state look
  • Update LibreHardwareMonitorLib
FanControl V275​
FanControl V276​
  • Update tray icons to use MaterialDesign context menu
  • Reordering of the icons should now be tracked properly by Windows. In app order no longer matters, as each icon can be moved in the notification area independently.
FanControl V277​
  • Fix a scaling bug with the tray icon context menu location
  • Fix a bug where a tray icon would no longer list the available configurations
  • Fix a bug where the tooltip would not appear on the tray icon
FanControl v282​
  • Make tray icons creation and update more robust to windows errors
  • Remove LHM's internal sensor value history to reduce memory usage
  • Fix some UI memory leaks
  • Make FanControl service tray icon mode work in non admin environment
  • Make FanControl process ask for elevation when started from a non-interactive environment
  • Fix a NvAPIWrapper bug
FanControl v283​
  • Fix Windows notification click action for updates
  • Add Exclude Usb Storage option from LHM
  • Fix a bug where the selected font would not apply
  • Fix a bug where numeric updown controls would be broken after moving a card
  • Fix default elevation for the scheduled task
FanControl v284 ​
  • Manual calibration now ignores control offset
  • Scheduled task now uses full path
  • Fix an ADLX bug
  • Mix Custom sensor now ignores null sensor values in Min/Max
  • Add missing translation location
FanControl V285​
  • Selected font applies to tray icon context menu
  • Fix bugs in Auto fan curve and Mix fan curve
  • Fix bug with File sensor
  • Remove LHM's built in sensor logging to reduce memory footprint
  • Fix memory leak with main window
  • Fix various service bugs
