- Dołączył
- 26 Maj 2010
- Posty
- 23597
- Reakcje/Polubienia
- 72158
FanControl v257
Fix a bug where custom sensors used in tray icons would throw an error at launch
- Fix a bug where the first launch sequence would not finish properly
- Add power monitor source to LHM
- Fix a display bug in tray icon page
- Fix a bug where speed sensors "hide" property would not get saved properly
- Fix a bug where having 2x the same plugin would cause refresh issues
- Fix a cache loading bug
- Fix tray icon tooltips
- Add support for any full config path with -c or --config cli option
- Update LibreHardwareMonitorLib
- Fix leaks in ADLXWrapper
- Fixed a logging bug
- Fixed a bug when cancelling the browse window when loading a config
- Fix empty sensor bug causing a crash
- Sign ADLX assemblies to avoid AV flagging.
- Update included version of PawnIO to 2.2.0
- New manual calibration feature: avoid regions
● Fix sensor names in service tray icons
● Launching the service on exit will create a tray icon
● Improved UI for RPM/% modes
