FBackup 6.1.188
Fix: Design changes for the languages displayed in the Options dialog
Fix: Updated Slovenian language for the interface
Fix: Updated Czech language for the interface
Fix: Updated Portuguese (Brazilian) language for the interface
FBackup 6.1.236
Fix: Fixed Google Drive error "Your browser is not supported anymore. Please update to a more recent one."
Fix: German translation was updated
Fix: Small display error correction for free disk space Statistics
FBackup 6.4 Build 309
New:
Quick Test action for backup jobs
Update:
Better detection for Removable/External drives
Translation support for labels used in notification emails
Updated multiple languages
Partial redesign for Check for updates
Fix:
Option to hide tray icon was overridden after an update
Small conflicts between different major versions on the same machine
Status for master password was not updated for Google Drive
File count progress was not displayed for Google Drive backups
Jarom
23 Wrzesień 2016
FBackup 6.5 Build 373
  • New: Added Burmese and Thai languages
  • Update: Interface updates for the setup screen
  • Update: German, Japanese, Portuguese, Slovak and Turkish translation updates
  • Update: Improved detection of removable drives
Jarom
23 Wrzesień 2016
FBackup 6.6 Build 388
  • Update: Japanese translation was updated
  • Update: Improved logging for backup servers
  • Fix: Import from previous version of Portable now works correctly
  • Fix: Check for updates failed in tray
Jarom
23 Wrzesień 2016
FBackup 7.0 Build 174
  • New: Cloud backup to Dropbox
  • New: Added CD/DVD as backup destination
  • New: Fast Mirror option to copy only new and modified files
  • New: Added option to copy NTFS file permissions for mirror backups
  • New: Added option to "Copy files in a subfolder"
  • New: Added new exclude filters for "Office temporary files", "Linux mapped drives", "Windows system files"
  • New: Added search option for the Plugin Management section
  • Update: Restyled the ribbon interface
  • Update: Navigation pane can be compacted and customized
  • Update: New structure for the New Backup Wizard
  • Update: Restructured the list of Options
  • Update: Modified application folders paths
  • Update: Option to customize the Quick Access Toolbar
  • Update: "Last Modified" folder date is now also restored
  • Update: Backups to Google Drive now show realtime progress
Jarom
23 Wrzesień 2016
FBackup 7.0 Build 199
  • Update: Quick Test option for Scheduler
  • Update: Improved loading of ribbon background image
  • Fix: Scheduled jobs were not imported correctly in some situations
  • Fix: Make sure backup catalogs are not in use during import
  • Fix: Edit scheduled task will display other tasks as modified
  • Fix: "Path not found" error for Dropbox backups
  • Fix: Destination folders were created in the root folder for Dropbox backups
  • Fix: Importing backup jobs with plugins in version 7
  • Fix: Restore default layout
FBackup 7.1 Build 251
Changes in FBackup 7.1.241 (12-December-2017)
  • New: System icons are now used for folders/files
  • New: Added new file date filter options
  • New: Interface available in French
  • New: Added Simplified Chinese translation
  • New: Added Indonesian translation
  • New: Interface available in Turkish now
  • New: Added Brazilian Portuguese translation
  • Fix: Job details are loaded better now
  • Fix: Do not ask for restart if user pressed Cancel during setup
Changes in FBackup 7.0.220 (17-November-2017)
  • Fix: Check if another installer is already running during setup
  • Fix: Send logs when installation fails is now a checkbox
  • Fix: Schedulers are moved to another job when duplicating a backup job
FBackup 7.1 Build 297
Changes in FBackup 7.1.297 (26-January-2018)
  • Update: Danish language is now updated
  • Update: Japanese translation updated
  • Update: Italian language partially updated
  • Update: Swedish language partially updated
  • Update: Added option to send anonymous usage statistics
  • Fix: Added new translatable strings
  • Fix: Restoring permissions from a Samba share had inconsistencies
