FBackup 7.2 Build 346
Changes in FBackup 7.2.346 (12-April-2018)
  • New: Option to Run backup after X minutes/hours (or at preselected time)
  • New: Added German language
  • New: Added Dutch translation
  • New: Added Portuguese (Brazil) language
  • New: Added Korean translation
  • New: Added Romanian language
  • Update: CD/DVD burning engine was updated
  • Update: Minor user interface language updates
  • Fix: No mapping for Unicode character exists in the target multi-byte code page
  • Fix: Temp folder is reset to default
FBackup 7.3 Build 373
Changes in FBackup 7.3.373 (17-May-2018)
  • New: General Data Protection Regulation compliance changes
  • Update: Check boxes displayed during setup are now more visible on Windows with no theme
  • Update: Minor GUI improvements
  • Fix: Control tab in Main window had hidden buttons
  • Fix: Help button from File did not work
  • Fix: Rotate disks on external disk option was not saving state
  • Fix: Don't show warning messages without user interaction
  • Fix: Always add command line in error log
FBackup 7.3 Build 403
Changes in Backup4all 7.3.403 (23-July-2018)
  • New: "Backup view is filtered!" notice and clear filter option
  • Update: Updated the Bulgarian language
  • Update: Updated the Japanese language
FBackup 7.4.497.0
Changes in FBackup 7.4.497 (11-December-2018)
  • Update: Improved the Italian translation
  • Update: Improved the Danish translation
  • Update: Improved the Block Backup type
  • Fix: Restoring backups with filters
  • Fix: Fixes for resumable uploads
  • Fix: Faster restore for block backups
Changes in FBackup 7.4.477 (18-October-2018)
  • Fix: Minor update for the News section
Changes in FBackup 7.4.475 (16-October-2018)
  • New: Use TLSv1.1 or later for cloud destinations
  • New: Retry copying backup catalogs to the destination
  • Fix: Small language corrections in Russian and French
  • Fix: Access violation error when saving column order
Changes in FBackup 7.4.461 (18-September-2018)
  • Fix: Empty News tab was visible in the Navigation options dialog
Changes in FBackup 7.4.457 (10-September-2018)
  • New: Backup Plugin for Microsoft Edge Favorites
  • New: Added Russian language for the user interface
  • Update: Improved speed of concurrent cloud backups
  • Update: Improved the Romanian translation
  • Update: Minor interface tweaks
FBackup 8.0 Build 122
Changes in FBackup 8.0.122 (11-April-2019)
  • New: Network backup is now faster and more reliable
  • New: Redesigned New Backup Wizard
  • New: Scheduler enabled/disabled icons were added
  • Update: Faster restore from remote destinations
  • Update: Log retry attempts on LAN
  • Update: Import at first run only if previous version is installed
FBackup 8.0 Build 141
Changes in FBackup 8.0.141 (24-April-2019)
  • Update: Romanian translation is now complete
  • Update: French translation is now complete
  • Update: Dutch translation is now complete
  • Fix: Access violation for network mirror backups using local catalogs
  • Fix: Mirror backups to Google Drive had warnings in certain situations
  • Fix: "A file with the same id already exists error" for Dropbox backups
Changes in FBackup 8.0.134 (18-April-2019)
  • New: Added filter for Windows.old folder
  • Update: Added more file types to the Documents filter
  • Fix: Scheduler status in list view always showed as disabled
  • Fix: Cannot install plugins via the plugin manager
  • Fix: Backup skipped files in special cases
Changes in FBackup 8.0.129 (16-April-2019)
  • New: Added Danish translation for the user interface
  • New: Saved destinations automatically appear in New Backup Wizard
FBackup 8.0.146.0
Changes in FBackup 8.0.146 (07-May-2019)
  • Update: Portuguese translation is now complete
  • Update: Brazilian Portuguese translation is now complete
  • Update: Korean translation is now complete
  • Fix: Scheduler was resetting to the current time in new backup wizard
  • Fix: Next button was deactivated on source selection page
FBackup 8.1 Build 195
Changes in Backup4all 8.1.195 (02-July-2019)
  • Fix: Save grouping for tables
  • Fix: Remote monitoring error when using different decimal separator
  • Fix: Flush remote monitor updates before sending the finish message
Changes in FBackup 8.1.183 (19-June-2019)
  • New: Remote monitoring support for backups and other actions
  • New: Option to show News page again after being hidden
  • New: Added job name instead of job ID in the description column
  • Fix: Navigation pane showed Expanded even with Collapsed/Off in options
  • Fix: Ensure folder exists before downloading file
  • Fix: Overwrite mirror files notification
  • Fix: Ensure cache is flushed when stopping the application
  • Fix: Destination was changed when opening multiple jobs at once
  • Fix: Display settings reset after restart
  • Fix: Reduce catalog loading time
Changes in FBackup 8.0.155 (15-May-2019)
  • New: Backup Data Deduplication files
  • Fix: Mirror Backup to CD/DVD source error
Changes in FBackup 8.0.148 (09-May-2019)
  • Fix: Minor fixes when backing up to cloud
Changes in FBackup 8.0.147 (08-May-2019)
  • Fix: Access violation error during startup for version 8.0.146
