iSpy 5.6.7.0
Fix for an issue with the new nVLC plugin
Fix for an issue with disconnection alerts
Added new functionality for grid views - they're now editable,supports full screen, always on top, context menus, and monitor selection
32bits
64bits
iSpy 5.6.8.0
Added multiple video transform options (rotate/flip)
Updates to disconnection alert system (supports different email addresses per object)
Added filter controls to the media panel
Updates to support group name options for the command line and http interface (specify a group to apply a command to instead of a specific object)
32bits
64bits
iSpy 5.7.0.0
Fixed a memory leak in ffmpeg
New storage management settings (supports saving to different folders/ drives)
New version of ffmpeg library
Running the update check in a background thread
Fixed an issue with restoring the window
Added continuous playthrough of selected media in the media panel
Fixed an issue with remote PTZ for some cameras
Re-wrote server ping logic
New folder browser dialogs
New disconnection/reconnection logic
Rewritten object list saving and loading logic
New grid view options for automatically displaying recent motion detected cameras or alerted cameras
New option for displaying feeds at correct aspect ratio in grid view
Webservice API updated
32 bits
64 bits
iSpy 5.7.9.0
Integrated common controls into the grid view
Added mic support into grid view
Fixed an issue with alerts/motion grid views
Pressing delete in the media panel now deletes media
Updated camera database
Added maximise to grid view (double click grid cell)
Added Fisheye correction option (see advanced video settings)
Fixed issue with mic alerts
Fixed issue with retention of storage management settings
Fixed an issue with the VLC plugin
Added an auto-off option to cameras to turn them off after a period of inactivity and a new alert action to turn cameras on.
32 bits
64 bits
iSpy 5.8.2.0
Fixed a few issues with internal timers
Fixed an issue with mic alert modes when using multimedia streams
Added positional zoom controls for mouse wheel zooming
Updated ffmpeg libraries
Added plugins to settings (you can now install plugins without restarting ispy)
Added an option to delete associated media when removing cameras and microphones
Changed timelapse frames to save to the grabs directory
Better autogeneration of object names (no more duplicates)
Added an option to VLC feeds to use the GPU for H264 decoding (experimental - may actually result in worse performance depending on your graphics card)
32 bits
64 bits
iSpy 5.8.3.0
Added positional zoom control to grid view (mouse wheel)
Fixed a couple of issues with simultaneous use of ispy with grid views (object in use errors)
Added view files option to grid view
Added a free virtual webcam driver so you can use cameras you have running in ispy in skype and other applications (alpha release any problems with it please post in the forums)
32 bits
64 bits
iSpy 5.8.6.0
Added option to archive media to a separate folder
Added full alerting options for disconnect/ reconnect events (see alert tab when editing camera and microphone)
Fixed some timer related issues
Fixed issues related to time changes (summer/winter time zone changes)
Added support for fractional second grab/ FTP
Moved Email templates to settings (see the messaging tab in settings to modify the email templates)`
Added grid views to main menu bar
Fixed an issue with cloned video sources
Fixed an issue with grid views
Added archive option to context menu in media panel
Added archive command to web interface
Fixed playback sequence order in media player
32 bits
64 bits
iSpy 5.8.9.0
Standardised display for mics and cams
Moved "connecting" text to bottom of frame
Fixed continuous pan issue when using Pelco
Fixed issue with PTZ scheduling
Fixed issue with enabling mics paired with cameras not being enabled on connection
Added some optional flags for rebrander application
Fixed issue with rebrander feature set flag overriding customisations
Stopped cameras/mics flashing if alerts are not enabled
32 bits
64 bits
iSpy 5.9.0.0
Added connecting notification to web vews when source is reconnecting
Fixed some memory issues related to grid view and remote viewing
Added option to archive instead of delete to storage management settings (global and object specific)
Changed "connecting" text to an icon (and moved it)
32 bits
64 bits
iSpy 5.9.2.0
Bug fixes related to FFMPEG streams
Added a virtual device manager for switching streams on the virtual webcam live without needing to use application settings (supports multi-view)
Removed the grid view options from the view menu and added a new grid view manager control to the toolbar
Some UI tweaks
Rolled back the FFMPEG library update (some reported instability with the latest update)
Fixed an issue with storage management
Improved responsiveness of FTP and Save Frames on motion detect code.
32 bits
64 bits
iSpy 5.9.3.0
Moved save frames to it's own tab
Added minimum interval to FTP and save frames
Added support for using SSL certificates (see settings)
Updated translations
Added new icons for all views
Added grid view to context menu
Added talk option "Local Playback" for remote talk and text via the browser
Improvements to FFMPEG UDP streaming
Made TCP the default option for FFMPEG
Fixed a hang issue with the IP camera scanner
Add maximise object option to context menu
Fixed a thread leak issue with the VLC plugin
32 bits
64 bits
iSpy 5.9.4.0
Updated Icons
Fix for corrupted frames in some RTSP feeds
Added an open program switch on snapshot option to settings
Moved FTP servers to settings
Added dropbox and google drive cloud integration (fully automatic and manual upload options)
32 bits
64 bits
iSpy 5.9.8.0
Fixed:
Issue with image and FTP settiings
Recording duration bug
Internal timer updates
Refresh issue with grid views
More responsive recording
Added:
Dual ranger for audio alerts
Snapshot mode for local devices
Automatic image settings checkbox
Video/Audio file merger
H265 Decoder (new version of FFMPEG)
Alert groups and new alert suspension logic (suspend alerts based on group camera activity)
Removed:
VLC 64 bit - install VLC 64 bit manually for future versions of iSpy 64 bit
32 bits
64 bits
