iSpy 6.0.7.0
Added PTZ flip support to USB devices
Simplified PTZ interface
Reduced CPU load when using FFMPEG sources
Updates to VLC sources
Added an FTP test option
Fixed an issue with cloned cameras
Update to Filter options
Fixed an issue with playback of slow framerate recordings
iSpy 6.0.8.0
Fixed an issue with VLC
32 bits
64 bits
iSpy 6.0.9.0
Fixed an issue with youtube uploads
Fixed an issue with grid view FPS limiting
Added ability to add objects to grid view when overlays are disabled
Added alerts and schedule on/off options to context menu
Removed recording icon if camera is reconnecting
Added "Switch Off Object" option to alert actions
Updated PTZ and source database
Graphical tweaks to grid view 4/28/2014
32 bits
64 bits
iSpy 6.1.0.0
Added multiple Picture in Picture support (overlay video from multiple other cameras)
Added None to PTZ options (to disable)
Added support for ePTZ for Fisheye cameras (using digital PTZ controls)
Fixed an issue with the setup project creating a desktop shortcut when told not to.
Added alert option to play sound through camera speaker
Added referrer authentication to lock down embedded streams
Reverted FFMPEG due to continuing issues with the recent FFMPEG builds
Fixed a bug with grid view empty cells
Fixed an issue with cloned cameras when the source camera has a transform applied
Fixed a bug with color background modeling
Added a PTZ scheduler switch to context menu switch option
Fixed an issue with google drive authentication
Added grid view options to view menu
Fixed an issue with alerting on no motion when enabling the camera
Fixed several issues with updating and moving media directories
Added HTTP keep-alives
32 bits
64 bits
iSpy 6.1.1.0
Fixed an issue with aborted google drive authentication blocking the ispy application
Modified VLC code to enable install without restarting iSpy
Removed http keepalives due to problem with MJPEG streams generating protocol errors
32 bits
64 bits
iSpy 6.1.2.0
Updated motion processing to calculate change percentages based on zones
Fixed a bug with FTP not saving passive flag
Fixed a bug with maximum number of cameras in grid view capped at 36
Added support for multiple levels of permissions based on password (see permissions in settings)
Added lock option to file menu
Fixed a bug with photo mode on local devices
Fixed a potential issue with FFMPEG timeouts
Fixed several issues with VLC audio sources
32 bits
64 bits
