Monkey's Audio 8.59​
August 30, 2022
  • Changed: Getting and setting album art creates a new object each time instead of using the last loaded one.
  • Fixed: Winamp could fail to start playback in some cases because the file wasn't being opened with FILE_SHARE_WRITE access.
Monkey's Audio 8.60​
August 31, 2022
  • NEW: Format Information is returned in the Winamp file information dialog.
  • Changed: Updated to Visual Studio 17.3.3.
  • Changed: The program is a little better about preserving the error codes issued during file open instead of returning a generic error
Monkey's Audio 8.62​
September 1, 2022
  • Changed: Made the file information dialog better report files with both APE and ID3 tags.
  • Changed: Made a definition of the wcscpy_s function to avoid unused variable warnings outside Windows (thanks Valérian Sibille).
Monkey's Audio 8.63​
September 5, 2022
  • NEW: Added a tag removal feature to the console program. Run it with -r to remove tags.
  • Changed: Added Warnings.h to the top level Shared folder in the SDK.
  • Changed: Made the disc number field define APE_TAG_FIELD_DISC simply "Disc" instead of "Disc #" to be more compatible with other tools.
  • Fixed: Robert Kausch submitted some source fixes / improvements (thanks!).
  • Changed: Removed the C++11 that slipped in (thanks Robert Kausch!).
  • Fixed: The 32-bit build could fail to encode due to an overflow (thanks Jukka Poikolainen)
Monkey's Audio 8.65​
September 6, 2022
  • Changed: Cleaned up the definition of WAVEFORMATEX.
  • Changed: Moved the definition of the constructor of WAVEFORMATEX to MACLib so warning 4514 would not occur.
  • Changed: Renamed the CLEAR macro to APE_CLEAR to avoid collisions with other projects.
Monkey's Audio 8.67​
September 8, 2022
  • Changed: Restructured CreateIAPEDecompressCore to avoid a warning.
  • Changed: Updated makefile (thanks Valérian Sibille).
  • Changed: Went back to APE_CLEAR for WAVEFORMATEX objects because the constructor was causing linking problems.
  • Changed: Added a newline to the end of all the files.
Monkey's Audio 8.68​
Version 8.68 (September 8, 2022)
  1. Fixed: The compression level was not capitalized in the menu after some recent changes.
  2. Changed: Corrected the remaining warnings.
  3. Changed: Moved the wave format back to MACLib and removed the header.
Monkey's Audio 8.92​
Version 8.92 (October 7, 2022)
  1. Changed: Moved that the APE namespace is being used into CPP files instead of the global header.
  2. Fixed: The Console header was relying upon undefined types, now correctly includes All.h.
  3. Fixed: NoWindows.h now defines TCHAR, LPTSTR, LPCTSTR outside of the APE namespace like on Windows.
Version 8.91 (October 7, 2022)
  1. Changed: Worked through the rest of the Clang-Tidy warnings.
  2. Changed: Turned on whole program optimization for the DirectShow filter (already on for everything else).
  3. Fixed: With the non-Windows standard file reader, reads that didn't read any bytes would be reported as successful, causing FFmpeg pipes to hang forever after reaching the end of the input file (thanks Valérian Sibille).
