Monkey's Audio 9.14​
Version 9.14 (February 14, 2023)
  1. Changed: Updated to Visual Studio 17.4.5.
  2. Changed: Made the file information dialog report a little better when opening on an unsupported WAV (because it's float for example).
Monkey's Audio 9.19​
February 22, 2023
  • Changed: Switched the APE info and APE tag classes to derive from interfaces (avoids needing to silence a warning during export).
  • Fixed: Building without Unicode set was not working well on Windows.
  • NEW: Added support for little endian AIFF files.
  • Changed: AIFF files other than sowt or NONE for the compression are rejected.
Monkey's Audio 10.05​
Version 10.05 (March 20, 2023)
  1. Changed: Removed the no longer needed IO.cpp file.
Version 10.04 (March 20, 2023)
  1. Changed: Made all processing happen when NULL is passed to GetData instead of no processing.
Monkey's Audio 10.08​
April 2, 2023
  • Fixed: When processing, if you would drag the program to a different monitor the toolbar would be created in the non-processing mode.
  • Changed: Column widths should maintain better dragging between different scaled monitors.
  • Fixed: Some files in the WAVE_FORMAT_EXTENSIBLE format would not start for the last few builds.
