V
vhick
Like to win Process Lasso because no doubt the best cpu process management. It offered many option compare to others.Although for the first time user, you found Process Lasso have complicated GUI, you don't need to configure anything after install. It just do the job perfectly. Of course, you can configure Process Lasso depends on your need with helpful caution so you can apply the function safely.
Thanks for the giveaway!
