Process Lasso 9.8.2.2
What's new in Process Lasso 9.8.2.2
July 8, 2020
  • Add option to switch power profile when Process Lasso starts
  • Keep Running and Watchdog launch actions now always launch unelevated (HKLM override available)
  • Suppress Dark Mode compatibility warning on older Windows 10/2016 builds
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
Process Lasso Pro 9.8.4.2
Changelog:
  • Show WSL and protected processes
  • Assorted fixes and enhancements
(37) GUI: Fix a redundant deallocation in a rare logic path (terminate attempted without sufficient access)
(37) Build: Improve debug symbol archiving
(35) Languages: Update PTBR
(33) Core: Emit specific log message if Keep Running feature is disabled due to license
(29) GUI: Active Processes Tab: Fix issue where terminated processes could persist in list under some scenarios
(27) GUI: Allow multi-select in Actions (log) listview (previously only supported in LogViewer)
(27) GUI: Further refactoring to support WSL and protected processes
(27) GUI: Improve failsafe icon for pathless processess
(27) GUI: Application Power Profiles Config Dialog: Clear edit box after add and prohibit duplicates
(25) GUI: Application Power Profiles Config Dialog: Handle double-click to remove listview items
(25) GUI: Application Power Profiles Config Dialog: Add 'clear all' button
(21) GUI: Supress to Dark Mode compatability warning on older Windows 10/2016 builds [backported to 9.8.2]
(19) Core: Allow Application Power Profile rules to be combined with 'Induce Performance Mode' on the same process [backported to 9.8.2]
(13) GUI: Add 'Options / Power / Always start Process Lasso with power profile' [backported to 9.8.2]
(7) Core: Keep Running and Watchdog launch actions now always launch unelevated (HKLM override available) [backported to 9.8.2]
(7) Core: Prohibit process launches when Governor-As-Service (HKLM override available) [backported to 9.8.2]
(1) GUI: Change default button on Application Power Profiles config dialog [backported to 9.8.2]
(1) Core: Fix an issue with Keep Running failing to launch some console apps due to DETACHED_PROCESS CreateProcess flag [backported to 9.8.2]
(0) GUI: Default 'ignore problematic processes' to False
(0) GUI: Show WSL and protected processes
Process Lasso 9.8.5.37
  • Allow Governor to be deployed as system service in the free edition
  • Default deployment type to Governor-as-Service for Server Edition
  • Support named config profiles with Governor-as-Service
  • Add function ‘Options / Memory / Purge standby list now’
  • Improve installer support for limited users by recognition of user initiating install
Process Lasso 10.0.0.164
Changes in Process Lasso 10.0.0.164 (March 12, 2021):
  • Refactored log system with CSV as primary
  • Ordered CPU affinity and priority rules
  • Periodic process sampling (snapshots)
  • GUI improvements
  • CrowdIn integration for translations
  • Numerous fixes and enhancements
Process Lasso 10.0.2.24
v10.0.2.24 – Apr 12 2021
  • Update several languages
  • Minor fixes and enhancements
(23) GUI: Language updates
(19) GUI: Remove 'Show notification when power plan changes' menu item
(13) GUI: Add Bulgarian
(11) GUI: Fix 'Log' menu caption not translated
(11) Core: Fix SmartTrim 'Trim Now' menu item didn't work with GaaS
(9) GUI: Change caption for 'Reconfigure the way Process Lasso starts' to 'Configure Startup'
(7) GUI: Minor cosmetic changes
(1) GUI/Installer: Minor code improvements
konarsky
28 Kwiecień 2011
Process Lasso 10.3.0
v10.3.0.50 – Oct 4 2021
  • New Config Profile Switcher feature
  • Add special ProBalance handling for searchindexer.exe
  • Other fixes and enhancements
(49) Core: Add ProBalance service exclusion overrides, first is searchindexer.exe
(49) Core: Minor ProBalance code maintenance
(47) GUI: Cosmetic improvements to Persistent CPU Priorities dialog
(45) GUI: Change 'File / Profile' menu to 'File / Config Profile'
(41) GUI: Set default IdleSaver time to 5 minutes
(39) GUI: Add confirmation dialog on config profile deletion
(37) GUI: Update German, Italian, Chinese Simplified, others
(35) GUI: Have 'Reset Configuration' also clear select registry backed settings
(33) GUI: Add tooltip to CPU Limiter dialog enforcement duration edit control to indicate that 0 means indefinite
(33) GUI: Add Windows version to About dialog
(31) GUI: Improvements to IdleSaver config dialog code
(31) Core: Fix to IdleSaver exclusion matches when username specified in rule
(31) GUI: Fix an issue where memory page priority rules could store with -1 values after being removed
(27) Core: Exclude any Steam child process running from "common\mixedrealityvrdriver" or "common\steamvr" subfolders from Performance Mode automatic game detection
(25) GUI: For rule additions by context menu, remove any matching exact (non-wildcard) full pathname rule before adding basename rule
(25) GUI: Change 'No default priority' and 'No default affinity' menu items to 'None' for consistency
(25) GUI: Add 'None' to multi-select persistent I/O priority context menu
(25) GUI/Core: Refactor some settings storage code
(23) GUI: Add menu item 'Options / Log / Set Max Log File Size' to set corresponding registry value
(23) GUI: Remove deprecated 'Keep log pruned' menu option and INI setting
(17) GUI: Remove deprecated code related to removed Active Processes tab CPU bar graphs
(17) GUI: Various improvements to Config Profiles
(15) GUI: Add error message on attempt to create config profile that already exists
(15) GUI: Manage Profiles Dialog: Fix 'Create New' would not always immediately refresh list afterwards
(15) GUI: Add Create Config Profile option to start with empty profile or copy current
(11) GUI: Change default config profile name to 'My First Profile'
(9) GUI/Core: Add Config Profile Switcher feature
(7) GUI: Fix issue where dynamic thread priority boost disabled rule removal by context menu wouldn't immediately re-enable boosting for that process instance.
(5) Installer: Refactor some language selection code
(1) SessionAgent: Fix crash on Windows 32-bit OSes
Process Lasso v10.3.1
(7) Core: Fix an issue in prior release where Performance Mode may not be induced per rule when process path is unavailable due to anti-cheat systems
(3) Core/GUI: Add Instance Balancer option to reserve n system CPU cores
(1) Core/GUI: Add Instance Balancer option to only include process instances with CPU use
(1) GUI: Minor string and cosmetic adjustments
Process Lasso v10.4.0
November 11, 2021
  • Installer: Do not show startup config dialogs by default (now optional section)
  • GUI: Small listview update optimizations
  • Core: Fix an issue where GaaS may not honor chosen language when writing log entries
  • Core/GUI: Add CPU Sets feature
  • GUI: Move Memory Priority process context submenu out of 'More'
  • GUI: Show Memory Priority column by default
  • GUI: Adjust config not writable message
  • GUI: Remove message when Forced Mode enabled
  • GUI: Cosmetic adjustments to CPU selection dialogs
  • GUI: Refactor CPU Affinity rules list dialog to be like that of CPU Sets (external selection dialog)
  • GUI: Do not throttle updates when check is manually invoked by user
  • GUI: Cosmetic to ProBalance Exclusions dialog
  • GUI: Adjust default position of columns in process listviews
  • GUI: Mark Efficiency Cores with "E" in CPU selection dialogs and menu items
  • GUI: Support Hyper-Threading disabled CPU affinities on Adler Lake
  • Core: Fix INI syntax error message after uninstalling BHP while application power profile rule referencing it exists
  • GUI: Cosmetic work to some rule list dialogs
