Process Lasso v19.0.0.94
19.0.0.94 – Nov 3, 2026
  • New LatencyTest tool
  • New Interrupt Affinity Policy tool
  • Minor fixes and enhancements
(9) GUI: New Interrupt Affinity Policy tool, IRQControl (Tools menu): choose which CPUs service each device’s interrupts, the interrupt priority and MSI mode; also available stand-alone
(13) GUI: New LatencyTest tool (Tools menu): measures DPC and ISR execution times per driver and per CPU, and thread wake latency; also available stand-alone
(33) All: Fix quoted command line switch values such as /startwithprofile=”My Profile” being ignored
(35) Governor: Assorted minor improvements
(37) Languages: Translation updates, fixes for clipped text, and message box buttons in the selected language
(45) Installer: Signed uninstaller
(53) Dark mode: Combo boxes, radio buttons, drop-downs and menu UAC shields are now dark
(55) GUI/Core: Better config reload when the config file is locked or unreachable
(61) GUI: New Tools menu: Bitsum programs, Windows tweaks and Windows utilities, including an online CPU/GPU/Memory Stress Test
(63) GUI: GPU Preference labels no longer swap High performance and Power saving on multi-GPU systems when Process Lasso itself has a Power saving GPU preference
(67) Installer: Various layout and functional improvements to the Startup Options dialogs
(69) Installer: Silent upgrades keep the selected language when the installing account has no saved installer language
(69) GUI: Performance Mode’s power plan setting is no longer replaced by a fallback plan after Select Power Profile is opened while the chosen plan is missing
(71) Installer: Silent installs and upgrades with /governor_start_type start the core engine the chosen way right away, and the Process Governor service survives the first restart after a fresh install
(75) All: CPU Limiter: New Scope setting to measure the combined CPU use of all matching processes, or of each user’s matching processes (e.g. on Remote Desktop and Azure Virtual Desktop hosts), and limit them together to a shared set of CPU cores. Rules now set the number of CPU cores to limit to; existing rules keep working as before. Older versions read a combined rule as a rule for each process
(77) GUI: If Process Lasso crashes while starting, for example while another program is hooking into it, it now restarts once by itself; crash dumps also record the exception for faster diagnosis
(85) GUI: Options > Log: the ProBalance begin and end log options are combined into one, Log ProBalance Events
(91) GUI: Improve behavior when /logfolder command line parameter is used
