Process Lasso 17.0.1.18​
v17.0.1.18 – Jan 1, 2026
  • Add menu to Edit Rules
  • Minor fixes and enhancements
(1) GUI: Fix process tooltips appearing underneath main window when “Always on top” was enabled
(3) GUI: Enable dark mode support to Named Config Profile dialogs
(3) GUI: Add menu to Edit Rules with config profile and file import/export actions
(11) GUI: Show active config profile in Edit Rules when applicable
(15) GUI: Adjust order of config profile menu items
(17) GUI: Copyrights to 2026
(17) GUI: Translation updates
Process Lasso 18.0.0.68​
Changes in 18.0.0.68:
Add GPU utilization
Improve primary graph appearance
Refactor ThreadRacer
Boost RegEx performance
(3) GUI: Cosmetic improvements to primary graph: anti-aliasing, area under CPU use filled, fonts, etc…
(13) ThreadRacer: Replace progressbars with CPU core heatmap
(13) ThreadRacer: Add selectable algorithm (integer, floating point, memory)
(13) ThreadRacer: Add selectable test duration
(13) ThreadRacer: Add report at end of run
(13) ThreadRacer: Mark 3d v-cache cores with a “v”
(13) ThreadRacer: Add dark mode
(17) GUI: Add GPU utilization
(19) CPUEater: Add dark mode support
(23) GUI/Core: Improve INI parsing of some rule types with certain complex match phrases
(25) GUI: Cosmetic work to Instance Count Limits dialog
(25) GUI: Add dark mode to config profile rename dialog
(27) GUI: Remove “(default)” decorator on stock config profile in menus
(31) Core: Improve performance when Regular Expressions are used for process matches
(35) GUI: Add View menu toggle for primary graph anti-aliasing
(39) GUI: Add per-process GPU utilization to the All and Active processes view
(39) GUI: Make GPU utilization one of the criteria for inclusion in Active processes view
(47) GUI: Improve paused bitmap rendering
(51) GUI: Add pause button to the upper tab control header for easy access
(53) GUI: Move Active Processes view threshold slider control to the rightmost position
(53) GUI: Append “(paused)” to the currently selected tab header when paused
(63) ThreadRacer: Add “(cache)” to 3D V-cache CCD button
(63) ThreadRacer: Allow window to be resized
Process Lasso 18.0.1.24​
v18.0.1.24 – Apr 15, 2026
(5) GUI: Translate “pause” button
(7) GUI: Add context menu to GPU utilization widget for an accessible way to disable it
(7) GUI: When GPU data collection is off, show a hyphen in the GPU process columns
(7) GUI: Minor optimizations
(9) Build: Expand post-build performance profiling
(9) GUI: Add custom color selection for GPU utilization
(13) GUI: Reduce GPU use in rendering of CPU cores graphs
(15) GUI/Core: Adjust RegEx caching to allow for delayed process metadata attribution
(17) ThreadRacer: Mark AMD chip-indicated fastest cores with an asterisk
(19) ThreadRacer: Move some strings to the resources
(21) GUI: Translation updates
(23) GUI: Dynamically size the pause button for longer languages
Process Lasso 18.1.0.44​
Changes in 18.1.0.44:
  • Add GPU Preference rules
  • Add display support for multiple GPUs
  • (1) GUI: Add multiple GPU support to the GPU widget and line graph
  • (3) GUI: Add GPU Preference rules
  • (3) GUI: Add toggle for whether line graph shows consolidated or individual GPUs
  • (3) GUI: Add multiple GPU support to status bar and tooltips
  • (5) GUI: Remove borders shown around CPU core graphs under some conditions
  • (15) GUI: Adjust log submenu ordering
  • (19) GUI: Add multiple GPU support to process lists
  • (21) GUI: Add a tooltip to the Active Processes threshold slider indicating value
  • (23) GUI/Core: Extend Regular Expression support to Instance Count Limit rules
  • (31) GUI: Add context menu to line graph with applicable View settings
  • (33) GUI: Translation updates
Process Lasso 18.2.0.50​
v18.2.0.50 – May 22, 2026
  • Add load-based power profile switcher
(1) GUI: Add load-based power profile switcher feature
(11) GUI: Extend per-process multi-GPU readings to the Active Processes view
(11) GUI: When showing multiple GPUs on the line graph, have GPU widgets use GPU line colors
(13) GUI: Add GPU numbers to line graph legend when showing multiple
(13) GUI: Fix an issue with the Japanese RAM load status bar partition
(15) GUI: Improve rendering of widget captions with larger text sizes
(15) GUI: Fix an issue where multiple identical GPUs could sometimes get filtered out in dedupe
(15) GUI: Add diagnostic data collection tool to the Help menu and About box
(17) GUI: Fix an issue with the Finnish translation that would prevent the GUI from opening
(17) GUI: Improve CPU and GPU widget graph tooltip behavior
(17) GUI: Add tooltip to the RAM widget
(19) GUI: Create distinct strings for actions due to verb subject ordering differences between languages
(19) GUI: Have action (e.g. terminate) confirmation messagebox list the specific process(es)
(21) GUI: Improve tooling around translation validation
(21) GUI: Fix an issue with the sort of CPU average column
(23) GUI: Add HKCU registry settings to override GPU widget colors “gpuColor1”, “gpuColor2”, …
(23) GUI: Adjust GPU preference rule string characters
(25) GUI: Add custom color selection menu items for present GPU adapters
(27) GUI: After reset custom colors is used, don’t change the theme to custom
(29) GUI: Remove adapter name suffix from GPU preferences when it would be identical
(29) GUI: Improve behavior of GPU Preference adapter names on systems with same-class GPUs
(33) GUI: Dynamically size Show/Hide Graph and Edit Rules buttons
(41) GUI: Add View option to control per-process GPU data collection (auto, all, visible rows only)
(43) GUI: Adjust GPU utilization aggregate total methodology to handle some edge cases
(49) GUI: Dynamically size View Log and Insights buttons
(49) GUI: Improve button padding when system font size is increased
(49) GUI: Translation updates
Process Lasso 18.2.1.6​
v18.2.1.6 – May 29, 2026
(1) Installer: Remove remaining incomplete translation warnings
(1) Translations: Improve consistency check tooling
(1) GUI: Fix to Finnish translation
(3) GUI: Add last 50 log entries to diagnostics report
(3) GUI: Refine GPU adapter dedupe
(5) GUI: Change GPU adapter numbering to start at 0
