Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
System Mechanic 21.0.0.14 Ultimate
What’s New in System Mechanic Pro 21.0.0.14 (December 23, 2020):
System Mechanic has a new look
A modern redesign streamlines and simplifies the user experience. Enhancements include:
  • New Streamlined installation flow. We significantly reduced the steps to install System Mechanic, given you quicker access to the powerful suite of System Mechanic products.
  • New Clean and simplified dashboard. We gave System Mechanic a fresh new look to showcase the best System Mechanic has to offer, while also making it easier for you to navigate through the product.
  • New In-product tutorials. Helpful dialog bubbles point you toward and guide the best use of the powerful features within System Mechanic.
New Network Scanner
This new feature scans for devices on your network using bandwidth that could be causing congestion.
  • If you are experiencing significant slowdown, it may indicate that router ports are open and vulnerable to inviting spoofed DNS and other malicious queries.
  • Hackers use automated scanners to check for open router ports and label them susceptible to attack.
  • Open ports will eventually attract attacks that try and guess your router login credentials, but threats go far beyond this.
  • Security cameras, thermostats, gaming consoles, smart TVs, phones, speakers and many other connected devices can be exposed to hacks.
  • You could even be recruited as part of a Distributed Denial-of-Service (DDoS) attack, which saps bandwidth you’ve paid for.
  • Network Scanner finds and lists active and potentially vulnerable devices, helping you avoid unnecessary slowdown and protect your home from malicious threats.
New Process Scanner
Now you can also scan your computer for processes that are currently draining the most system resources, likely leading to preventable slowdown.
  • The perfect complement to the bloatware-finding feature Startup Optimizer
  • Lists unnecessary processes currently running in real time
  • The most system-taxing items are listed first
  • Recommends terminating or uninstalling apps you may no longer need
New in System Mechanic Pro and System Mechanic Ultimate Defense:
All of the above System Mechanic features are included in System Mechanic Pro and System Mechanic Ultimate Defense, plus:
Enhanced Antivirus Protection
The real-time antivirus protection System Shield® has been updated with a new AV engine to intelligently discover and block the latest threats.
  • AI-based threat detectionLike Malware Killer, System Shield now uses machine learning to spot potential new threats. The new artificial intelligence trains itself with ever-improving models to identify suspicious behavior without depending on existing malware samples as a reference.
  • Macro variant detectionThis new feature looks for new versions of known Macro viruses, which are particularly stealthy viruses written using macros typically found in word processing applications.
  • Packed executables detectionViruses that are “packed” have been compressed, and will decompress at run time. This malicious tactic turns known threats into something much harder for scanners to detect. The new System Shield identifies suspicious packed files, even if they are not yet recognized as malware.
  • Improved virus definitions The new streamlined infection signature process delivers a smaller footprint, with more efficiency and laser-focused precision.
System Mechanic Pro 21.3.1.76
May 31, 2021
  • A modern redesign streamlines and simplifies the user experience. Enhancements include:
  • New Streamlined installation flow:
  • We significantly reduced the steps to install System Mechanic, given you quicker access to the powerful suite of System Mechanic products.
  • New Clean and simplified dashboard:
  • We gave System Mechanic a fresh new look to showcase the best System Mechanic has to offer, while also making it easier for you to navigate through the product.
  • New In-product tutorials:
  • Helpful dialog bubbles point you toward and guide the best use of the powerful features within System Mechanic.
  • New Network Scanner:
  • This new feature scans for devices on your network using bandwidth that could be causing congestion:
  • You could even be recruited as part of a Distributed Denial-of-Service (DDoS) attack, which saps bandwidth you've paid for.
  • New Process Scanner:
  • Now you can also scan your computer for processes that are currently draining the most system resources, likely leading to preventable slowdown:
  • The perfect complement to the bloatware-finding feature Startup Optimizer™
  • Enhanced Antivirus Protection:
  • The real-time antivirus protection System Shield® has been updated with a new AV engine to intelligently discover and block the latest threats.
  • AI-based threat detection:
  • Like Malware Killer, System Shield now uses machine learning to spot potential new threats. The new artificial intelligence trains itself with ever-improving models to identify suspicious behavior without depending on existing malware samples as a reference.
  • Macro variant detection:
  • This new feature looks for new versions of known Macro viruses, which are particularly stealthy viruses written using macros typically found in word processing applications.
  • Packed executables detection:
  • Viruses that are “packed” have been compressed, and will decompress at run time. This malicious tactic turns known threats into something much harder for scanners to detect. The new System Shield identifies suspicious packed files, even if they are not yet recognized as malware.
  • Improved virus definitions:
  • The new streamlined infection signature process delivers a smaller footprint, with more efficiency and laser-focused precision.
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
System Mechanic Pro 22.3.3.175​
Homepage :
System Mechanic 22 Professional Features:
  • LiveBoost boosts system responsiveness through real-time calibration of CPU, RAM and Drive.
  • PowerSense dynamically senses your resource needs and switches power settings and processor modes in real time for best performance.
  • Ultra Performance Mode focuses maximum PC power on the high demand app you have running.
  • Endurance Mode intelligently conserves system resources when maximum battery life is a priority.
  • Stability Guard intercepts stability threats to keep Windows fast and problem-free.
  • NetBooster speeds up internet, videos, downloads and games.
  • ActiveCare uses set-and-forget patented technology to maintain your PC automatically
  • Total Registry Revitalizer resolves registry problems and stabilizes Windows.
  • AcceleWrite real time technology optimizes file write speeds
  • PC Cleanup cleans up over 50 types of junk files.
  • Program Accelerator re-aligns disjointed program files.
  • Memory Mechanic reclaims wasted RAM in real time.
  • CRUDD Remover locates and removes unused extra programs.
  • Startup Optimizer automatically accelerates PC startup 22 ways.
  • Privacy Cleaner wipes internet and chat history, clutter and cache.
  • Includes System Shield AntiVirus and AntiSpyware:
  • Protects against over 2.1 million different viruses and threats
  • Never gets in your way with annoying popups or confusing alerts
  • Permanently removes any stubborn infection
  • Invisible real-time protection uses less memory and CPU resources
  • Gamers and power users rejoice-you no longer have to disable your protection!
  • No-compromise intelligent design for absolute security and quick system response
System Mechanic 22.5.1.15​
August 8, 2022
  • Enhanced Maximum speed on demand:
  • On-Demand Boost™ improves your PC’s responsiveness and performance whenever you choose. One click suspends non-critical, currently running Windows® services that could be draining precious system resources.
  • On-Demand Boost is now even better at boosting “power sessions” such as gaming, rendering video, and other resource-intensive tasks.
  • Previously disabling only Windows services, now On-Demand Boost offers you the ability to select specific processes associated with the apps installed on your computer.
  • Just choose from an automatically-generated list of available processes you can hibernate to increase system speed even more.
  • New Advanced privacy and data-mining protections:
  • New features in Privacy Guardian™ can now prevent both the operating system and your installed apps from accessing and sharing a wide array of personal information. Available in System Mechanic as a trial and in System Mechanic® Ultimate Defense™.
  • Some of the operating system default settings now easily disabled include:
  • Document libraries access
  • Picture libraries access
  • Video libraries access
  • Contacts access
  • Calendar access
  • Email access
  • Messaging access
  • Call history access
  • Notifications access
  • These locations may contain private images, information, or correspondence you don’t wish to share with third-party apps installed on your computer. Privacy Guardian makes turning them off simple.
  • Additional settings Privacy Guardian allows you to disable include:
  • Phone calling:
  • When phone calling is turned on, you are allowing apps to make phone calls from your computer.
  • Because your OS uses your cellular service to make phone calls, you may be charged unexpected fees from your cellular service provider.
  • Device radio control:
  • The radios in your devices, such as WiFi and Bluetooth, are used by some apps to send and receive data.
  • Permitting apps the ability to turn radios on or off relinquishes control over this type of data-sharing to the permitted apps.
  • Tasks list access:
  • Enabling this setting allows your installed apps access tasks in Outlook or other task-tracking apps.
  • The tasks list is a detailed record of user tasks you may not want to share with third-party apps, in particular if you have created highly personalized tasks.
System Mechanic 22.7.1.35​
October 17, 2022
  • Privacy enhancements include:
  • New Network Scanner Enhancement:
  • Detect and protect all software-compatible devices using your home’s network with a few simple clicks.
  • New Fingerprinting Extension:
  • Hide your browsing habits and avoid invasive trackers when you install our digital fingerprinting extension.
  • New Protect More Devices:
  • Keep all your home devices covered, with easy-to-use network identification. Protect up to 10 devices with only one paid subscription.
  • Added features & enhancements:
  • System Mechanic ® Ultimate Defense™ customers will enjoy:
  • Privacy Guardian Fingerprinting Extension:
  • Included within the Privacy Guardian toolbox is our new digital fingerprinting extension.
  • ByePass Password Manager:
  • Store all your usernames and passwords in one place with our secure password manager.
  • System Mechanic®, System Mechanic Pro® & System Mechanic® Ultimate Defense™ users will enjoy:
  • Network Scanner Device Identification:
  • Network Scanner now includes an easy-to-use tool that detects whether devices running on your home’s network have System Mechanic installed.
System Mechanic 23.5.1.77​
What’s New in System Mechanic 23.5:​
New: Fingerprinting Protection​
No longer browser-dependent, improved Fingerprinting Protection hides your online habits from potential trackers. Block trackers in real time and shield your personally identifiable information from websites and advertisers.
  • Easily toggle protection on or off
  • Choose which trackers you block or allow
  • Block cookies (the storage of your unique data)
  • Easily view your masked fingerprinting history
New: User-friendly Privacy Permissions​
New user-friendly navigation lets you easily configure permissions and manage data sharing effortlessly for both Windows and third-party applications. Easily configure permissions, manage data sharing, and safeguard your personal information with a seamless and intuitive interface. Take control of your privacy with confidence and simplicity.
How to use:
  • Open System Mechanic Ultimate Defense and click on ‘Privacy’
  • Locate the ‘Windows Privacy’ heading and the dropdown box on the right side
  • Select a preset configuration or click on ‘Custom’
  • Clicking on the small box with the arrow will reveal custom privacy details
  • Use the toggles to turn permissions On and Off
System Mechanic & Startup Optimizer boost your PC’s startup time​
How to use:
  • Open application and click on ‘Performance’
  • From the Performance Home dropdown, select ‘Toolbox’
  • Find and click on ‘Startup Optimizer’
  • Startup Optimizer will scan and find potentially unwanted items slowing boot-up time
  • Review each item, see community recommendations and impact on performance
  • Choose to allow each item to open on start, delay, or be turned off
