Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
System Mechanic 25.5.0.3​
What’s New in System Mechanic 25.0:
Added a feature and enhancement called AppPrioritizer.​
This new feature helps maximize the performance of your favorite apps by automatically prioritizing them for peak efficiency. AppPrioritizer ensures your most demanding applications run smoothly and prevents lags by allocating CPU resources where they are needed most.
AppPrioritizer is your new go-to tool for ensuring that your favorite apps run at peak performance, with no interruptions.
  • Tailored Prioritization – Customize which apps receive the most CPU resources, ensuring smooth performance for the applications that matter most to you.
  • Efficient Multitasking – Load balance other apps to prevent CPU stress while your prioritized apps get the resources they need.
  • Optimized Application Summary – Stay informed when AppPrioritizer optimizes your CPU, keeping your system running efficiently behind the scenes.
AppPrioritizer is available in System Mechanic Standard, Pro, and Ultimate Defense
System Mechanic 25.7.0.4​
  • ByePass+ Password Manager:
  • Protect your digital life with the new ByePass+ — delivering the same trusted convenience with enhanced encryption security. Safeguard your logins, autofill credentials effortlessly, and access everything with one master password. Your data has never been safer.
  • Smart ActiveCare:
  • Let Smart ActiveCare boost your PC’s performance — an AI-powered tool that intelligently schedules maintenance and repairs at times that work best for you.
  • SafeWeb:
  • Introduced in the last version, AppPrioritizer is your go-to tool for ensuring that your favorite apps run at peak performance, with no interruptions.
