USB Drive Letter Manager (USBDLM)
USB Drive Letter Manager (USBDLM) 5.5.0
V5.5.0 (27 June 2021)
  • Bugfix: On deregistration of the USBDLM service no-letter entries created by USBDLM where not removed, so the drive did not get a drive letter assigned
  • Bugfix: Under Windows 8 and 10 OnArrival for Bitlocker drives was executed immediately instead after unlock. Now twice, see Bitlocker.
  • Bugix: UsbDriveInfo could not swap or steal drive letters since V5.4.8 because it showed a OK only messagebox instead of Yes/No which is hard to answer with Yes.
  • New: USBDLM's balloon-tips and UsbDriveInfo look better under Windows 10 with a display scale > 100% (they are "DPI aware" and therefore no more bitmap-scaled)
USB Drive Letter Manager 5.5.2​
V5.5.2 (24 July 2022)
  • New: USBDLM removes the drive letter of Windows "System Reserved" partitions on MBR drives (which get a drive letter assigned when a system drive is put into a USB case)
  • New: Variable and criteria UsbPortMaxSpeed, e.g. for customized balloon-tips
  • New: Optional polling for new media and the no media no letter feature (for a few DVD drives which fail to send a proper notification)
  • New: UsbDriveInfo handles empty CD/DVDs better
  • Bugfix: Some problems with BitLocker To Go fixed
USB Drive Letter Manager (USBDLM) 5.5.3
V5.5.3 (25 July 2022)
  • Bugfix: USBDLM.msi V5.5.2.x failed to update any older installed version
  • Bugfix: UsbDriveInfo V5.5.2.0 could not start the Windows Disk Manager, Device Manager and Event Viewer
  • Conclusion: I should release Beta versions again
USB Drive Letter Manager 5.5.4​
August 1, 2022
  • Bugfix: USBDLM since V5.5.2 removed the drive letter of GPT partitions with the attribute in bit 63 set (GPT_BASIC_DATA_ATTRIBUTE_NO_DRIVE_LETTER, diskpart calls it "nodefaultdriveletter"). Now USBDLM just does not touch the drive letter of such volumes. As before you can let USBDLM ignore the attribute by IgnoreNoDefaultDriveLetterAttribute=1 in section [Settings]
USB Drive Letter Manager (USBDLM) 5.5.5​
V5.5.5 (04 September 2022)
  • Rollback: As before V5.4.9 USBDLM ignores the GPT attribute GPT_BASIC_DATA_ATTRIBUTE_NO_DRIVE_LETTER (Bit 63). Background: I had no idea where this attribute comes from. It turned out that this attribute is often not set intentionally, it is set by the Windows Disk Management when a drive letter is removed. This makes no difference on the computer where it is done but the drive will get no letter assigned on any other Windows computer by default too. When this behaviour was implemented 20 years ago portable drives > 2 TB (which need GPT partitioning) where probably beyond imagination...
  • New: UsbDriveInfo can edit GPT partition attributes (right-click on a volume -> Edit -> GPT Partition Attributes)
USB Drive Letter Manager 5.5.7​
January 22, 2023
  • Bugfix: USBDLM may crash when arrival and removal events are triggered in fast succession for the same drive
  • Bugfix: UsbDriveInfo showed a messagebox after writing a report by command-line
  • Bugfix: UsbDriveInfo showed "Error path not found" on Tools -> Compact VHD
USB Drive Letter Manager 5.5.8​
V5.5.8 (21 May 2023)
  • New: New function "uninstall a USB device" for the command interface
  • New: BalloonTips and UsbDriveInfo look better on high DPI scale
  • Bugfix: Criteria VolumeLabel did not work in [OnArrival] for manually unlocked Bitlocker volumes
USB Drive Letter Manager 5.6.0​
Feb 26, 2024
  • Bugfix: Blurry balloontip icons at 125% Windows display scale
  • Bugfix: Criteria VolumeLabel did not work on ReFS formatted drives
  • Bugfix: UsbDriveInfo crash when the UsbDriveInfo.ini exist but not writable
  • Bugfix: UsbDriveInfo with small font in the right pane on high DPI if there is an INI written by version before V5.5.8
  • New: Criteria Container for drive letters depending on the VHD container
  • New: Variables "ContainerPath" and "ContainerFile" for VHD container in mount-points or balloon-tips
  • New: UsbDriveInfo option to show hidden volumes
USB Drive Letter Manager 5.6.3​
Nov 12, 2024
  • Bugfix: DriveLetter=%ContainerName%xxx to mount a VHD beneath its container did not work
  • Bugfix: Suppressing Windows BalloonTips might empty a "modern" Windows dialog shown in a similar place as a BalloonTip
