USB Drive Letter Manager (USBDLM)
USB Drive Letter Manager 5.7.0​
Dec 16, 2024
  • New: UsbDriveInfo can set volume's volume label, on exFAT up to 15 characters which was supported up to Windows 7 (format.exe and label.exe). Newer systems limit this to 11 but still read 15 without a problem
  • New: UsbDriveInfo can set a GPT partition's Partition Name which is up to 35 characters long
  • New: UsbDriveInfo can set a GPT disk's Disk ID GUID with the option to use ASCII values only, abusing it as 16 characters ASCII text disk label
  • New: Criteria GptPartitionName
  • New: USBDLM has GPT partition's Partition Name available int the variable %GptPartitionName%, so it can be used as mountpoint name or as label in the Windows Explorer using an [Explorer] section
  • New: USBDLM has GPT disk's GPT Disk ID GUID interpreted as 16 characters ASCII text in the variable %GptDiskIdGuidAsText% (UsbDriveInfo can edit it that way), so it can be used as mountpoint name or as label in the Windows Explorer
  • New: On system with multiple active user sessions balloontips can be restricted to a certain user group or user (instead of showing the balloon-tip in all sessions)
USB Drive Letter Manager (USBDLM) 5.7.3
V5.7.3 (6 July 2025)
  • Bugfix: Criteria VolumeLabel did not work on ReFS volumes
  • New: UsbDriveInfo function "Compact VHD" can choose now between NTFS file system based compactation and write+scan for zero-blocks
  • New: New function "Compact VHD" for the command interface used by the new
    command-line tool
