- Dołączył
- 26 Maj 2010
- Posty
- 13089
- Reakcje/Polubienia
- 44219
FanControl v146
March 25, 2023
- You can now hide custom sensors
- Update LibreHardwareMonitorLib
- New offset custom senso
- Fix tray icon bugs
- Identification dialog will now also rename the corresponding speed sensor
- Update process now has checksum validation
- Fixed a bug where dialogs would be invoked while the window is not visible.
- Fixed a bug where the window would always be shown after sleep.
- Updater now works properly for both NET 7.0 and NET 4.8 releases
- Updated LibreHardwareMonitorLib
- InpOut is now opt-in
- The dotnet version of the program is now indicated next to the version number in the hamburger menu
- Fix time average sensor logic
- Fix an instance where the main window would pop up on start
- Added sponsor button
May 15, 2023
- Add warning for InpOut
- Small bug fixes
Fixed a bug in V158 where sensors would be duplicated
- Create new configuration (blank) dialog
- The background and foreground color now change slightly based on your primary color
- Hamburger is back, sort off. It will now show/hide the column menu on the side.
- You can now opt out of the update popup at startup in the settings page.
- An icon will be displayed near the top right three dot menu when an update is available.
- Updated LibreHardwareMonitorLib.
