Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
Process Lasso 9.4.0.28
v9.4.0.28 – Nov 1 2019
  • GUI: Support Windows 10 Dark Mode and interface with OS setting
  • GUI: Dark Mode improvements
  • GUI: Add tooltips to CPU utilization graphs
  • GUI: Show active config profile on graph, if used
  • GUI: Self-restart now opens with main window visible
  • GUI: Fix governor could be inappropriately stopped by GUI on session exit
  • Core: Fix use of Performance Mode when Governor running as service
  • Core: Fix ‘Hide Suspended Processes’ was defaulting to true
  • TweakScheduler: Zero ratio bits when fixed length quanta used
  • InstallHelper: Preserve character case of global config path
  • InstallHelper: New modern browse dialogs for global log and config folders
  • All: Many other optimizations, fixes and enhancements
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
Process Lasso 9.4.0.46
v9.4.0.46 – Nov 7 2019
  • Minor fixes and enhancements
  • Update Chinese and Slovenian
Process Lasso 9.4.0.70
v9.4.0.70 – Nov 26 2019
  • GUI: Active Processes: Add sensitivity adjustment slider shown above list
  • GUI: Fix to ‘File / Choose alternate log folder’
  • GUI: Dark Mode support for Windows 10 19025
  • GUI: Several other small and cosmetic enhancements
  • Log: Standardize CSV output, adding headers, quotes and removing BOM
  • Log: LogViewer: Add full history CSV export in addition to current view export
  • Log: Fix main GUI ‘File / Export log to CSV’ would not export full history
  • Core: Improved process suspend function, now compatible with Resource Monitor
  • Core: Improved legacy hard throttle function
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
Process Lasso 9.6.0.68
  • Add per-session agent to facilitate some features with governor-as-service
  • Numerous improvements and fixes to limited user environments, especially when combined with governor-as-service
  • IdleSaver now available with governor-as-service
  • Improvements to IdleSaver configuration, allowing broader range of settings
  • Add back Spanish, Italian, Polish, and French languages
  • Considerable other product refinement
