Process Lasso 12.3.0.24
Changes in 12.3.0.24:
  • Process status column 'Running' state is now implicit if no other notable state
  • Include Efficiency Mode in process status column
  • Core/Add Efficiency Mode rules
  • Improve tab ordering in ProBalance advanced options dialog
  • Core/Add ProBalance option to use Efficiency Mode during restraints
  • Functional improvements to ProBalance advanced options dialog regarding dynamically enabled/disabled suboptions
  • Make persistance of custom System Timer Resolution a Pro feature
  • Don't show 'Balanced' power plan in 'Start Process Lasso with power plan' submenu on power mode systems (only the overlays)
  • Expand width of match phrase edit controls in Watchdog and Disallowed Processes dialogs
  • Add double-click to remove item and populate edit box in Disallowed Processes dialog
  • Add 'Access denied' messagebox if changing current priority class by context menu fails
  • Change affinity set error to 'Access denied' to match priority change error
  • Swap default column positions of 'Status' and 'ProBalance time'
  • Change IdleSaver exclusion rule symbol from 'e' to 'f'
  • Set Efficiency Mode ON and OFF rule symbols to 'E' and 'e', respectively
  • InstallHelper: Make CoInitializeSecurity failure a non-critical error
Process Lasso 12.3.1.20
v12.3.1.20 – July 18 2023
  • Minor fixes and enhancements
(1) GUI: Add new variable to Watchdog launch action, %5 for session ID (or use %sessionid%)
(3) GUI: Rename process context menu item 'Application Power Profile' to 'Power Profile'
(5) Installer: On new install, ensure config file is initialized prior to Governor start, eliminating an inconsequential load error log entry
(7) GUI: If Governor service is disabled, reenable it automatically when user tries to start it
(9) Insights: Fix sort preference could be lost when ProBalance event occurs while dialog open
(9) Insights: Improve sort of frequency of action column
(9) Insights: Persist sort-by and direction preference
(11) GUI: Fix tray icon tooltip could show stale info under some circumstances
(13) Install: Add localized description to Governor service
(13) Install: Refactored service management code to remove legacy MakeService executable (bitumms.exe)
(15) MMSC: Remove superfluous warning from Multimedia Scheduler Configuration Tool
(15) GUI: Add 'Locate / Properties' process context menu item to invoke the shell file properties dialog
(17) GUI: Fix three strings whose translations were not being applied
(19) Core: Fix Instance Balancer non-regex wildcard matches weren't being tested against pathnames
Process Lasso 12.3.2.20
v12.3.2.20 – Sept 1 2023
  • Tie idle priority class to Efficiency Mode to match Task Manager’s behavior
  • Fix an issue where cores could incorrectly show as parked on Intel 12th+
    (also impacts Task Manager and Resource Monitor)
Process Lasso Pro 12.4.0.44
  • E-core distinction in graphs
  • Delayed CPU affinity rules
  • ‘Remove all rules’ process action
(1) GUI.CoreGraphs: Owner draw on light themes too (changes appearance)
(1) GUI.CoreGraphs: Append 'Efficiency' to tooltip when E-core
(1) GUI.CoreGraphs: Overlay leaf icon on Efficiency cores
(7) GUI: Fix issue where rules column wouldn't immediately refresh after automated config profile switch
(9) GUI: Add ProBalance option to not change CPU affinity if already customized
(11) ThreadRacer: Expand to 16 threads plus one with selectable affinity
(11) ThreadRacer: Add message if start attempted with no selected threads
(11) ThreadRacer: Disable checkboxes while started
(11) ThreadRacer: Add 'invert selection' and 'clear' buttons
(13) GUI.InstanceBalancer: Add confirmation if dialog dismissed via OK button with unadded rule in controls
(13) GUI/Core: Add CPU affinity rules setting to delay enforcement, for games that have trouble at startup with custom affinities
(21) GUI: Address assorted minor localization issues (control widths, etc...)
(23) GUI: Color tweaks
(25) GUI: Don't show CPU cores in context menus if more than 32
(27) GUI: On heterogenous systems, when a new Performance Mode rule is added by context menu, ask if an Efficiency Mode OFF rule should also be created.
(27) GUI: Don't show success messages when rules created by process context menu
(27) GUI: Add 'General / Bitsum Highest Performance' submenu and new 'Reinitialize' action
(27) Core: Set Bitsum Highest Performance to prefer performant processors (P-cores) for short and long running threads when plugged in
(29) GUI: Minor cosmetic and menu tweaks
(29) GUI: Add 'Remove All Rules' action to process context menus (single and multi-select). This removes all rules defined exactly for this process. Other matching wildcard rules may remain.
(31) GUI: Various minor cosmetic improvements
(31) GUI: Periodically refresh total installed RAM shown in status bar for dynamic VMs
(39) GUI: Have ProBalance drop one random core setting honor existing or configured CPU affinity
(39) GUI: Remove ProBalance option 'round robin affinity', migrating to 'drop one random core'
(39) GUI: Remove Watchdog set affinity action option 'round robin'
Process Lasso 12.4.1.10
v12.4.1.10 – Oct 13, 2023
(1) Build: Remove redundant digital signature on some modules
(3) Core: Move IdleSaver recovery info for improper termination to registry
(3) Core: Adjust cleanup order when exiting with app power plan, performance mode and/or IdleSaver active
(5) Core: Fix an issue where Efficiency Mode OFF rules were enforcing a normal priority class, overriding any other priority rules on the process
(5) GUI: When turning Efficiency Mode OFF, only reset the priority class if it was previously idle
(7) GUI: Adjust some legacy module file versions to be consistent with product version
Process Lasso v12.4.4
(1) GUI.AffinitiesDialog: Add 'Show Advanced' link and hide delay edit control by default
(1) GUI/Core: Allow wildcards in Performance Mode basename matches (previously only full paths)
(5) GUI: Add IdleSaver exclusion list management to its config dialog
(11) GUI: Disable automatic game detection for Performance Mode by default for new installs
(11) GUI: Change order of 'Options / Power' submenu and move Bitsum Highest Performance options from General
(13) Core: Fix an issue where processes with 0 threads were not being treated as suspended
(13) Core: Fix an issue where enforcing Efficiency Mode on a suspended process could result in a zombie process under some conditions
(15) GUI: Extend retries if tray icon addition fails, and exit with message if it ultimately fails
