Process Lasso 10.4.2
v10.4.2.16 – Jan 5 2022
  • Add CTRL+SPACE keyboard accelerator to pause GUI display updates
  • ‘Start Process Lasso with power profile’ now acts as a base power profile when no power rules active
  • Minor fixes and enhancements
(1) Core: Minor adjustment to Windows Error Reporting (WER) snapshot process handling
(1) GUI: Add CTRL+SPACE keyboard accelerator to pause GUI display updates
(3) GUI/Core: When no power profile rules are in effect, return to set 'Start Process Lasso with Power Profile'
(5) GUI: Add message when user attempts manual switch of active power profile when 'start with' (base) power profile is set
(7) GUI: Don't remove processes from listview while in the context menu. Fixes crash seen when process removed while taking action on it via context menu.
(9) GUI: Remove 'Help / Change License Code' menu item when not activated
(9) GUI: Fix activation code change wouldn't refresh licensee name on graph until app restart
(11) All: (c) 2021 to 2022
(11) GUI: Add menu item to toggle ProBalance option to lower to Idle instead of Below Normal
(13) GUI: Add submenu 'View / Reset'
(13) GUI: Add menu item 'View / Reset / Reset ProBalance Counters'
(13) GUI: Move process context menu item 'Keep Running' to 'More' submenu
(13) GUI: Improve consistency of process context menu items for Hard Throttling
(13) All: Minor code maintenance
Process Lasso Pro 10.4.4.20
v10.4.4.20 – Feb 18 2022
(1) All: Switch to 2022 EV code signing certificate
(1) GUI: Improve signal to update licensee name display when activation status changes
(3) GUI: Fix tray icon wasn't changing to indicate a ProBalance action with GaaS
(5) GUI: Add 'View / Tray Icon' menu option to toggle changing of tray icon upon ProBalance action
(5) GUI: Add HCKU registry setting 'TrayProBalanceIconDurationMS' to adjust duration ProBalance icon is shown in tray upon action (default 1500ms)
(5) GUI: Fix CPU utility and time were transposed in status bar
(7) GUI: Fix an extraneous registry key created in last release
(11) GUI: When Watchdog or Keep Running rules require GaaP, show notice and one-click 'switch to GaaP' syslink in their config dialogs
(13) GUI: Add /trimnow command line switch to initiate SmartTrim action
(13) Core: Log error with guidance if Watchdog rule can't restart a process due to GaaS
(17) GUI: For post-trial free installs, now allow Pro-only rule config dialogs to be opened, but restrict 'Add' button
Process Lasso v11.1.1
v11.1.1.26 – Oct 10 2022
(1) Installer: Enable Spanish language selection
(3) GUI: Improvements to product activator
(5) GUI: When filter edit controls have focus, TAB can escape to their respective listview
(7) GUI: Add dark mode to some frequently seen dialogs
(11) Core/GUI: Default core parking adjustment log entries to ON (when done by ProBalance, if option set)
(11) Core: Fix an issue where some log entry types could continue to be emitted despite logging disabled
(11) GUI: Add menu items to toggle logging of CPU Sets and Group Extender rules
(13) Core: Adapt ProBalance option 'Disable CPU Core Parking during action' to Intel 12th Gen
(13) Core: Change failsafe recovery core parking options from HKCU to HKLM (used after improper Governor shutdown if ProBalance option 'Disable CPU Core Parking during action' was used)
(15) GUI: Fix an issue where clearing the log while it is updating could deadlock
(15) Core: Fix an issue where a Watchdog rule that restarts a service may fail to do so
(17) GUI/LogViewer: Minor improvements to log monitoring thread
(17) GUI/LogViewer: Use filesystem change notifications on UNC paths when available
(17) GUI.WatchdogRulesDialog: Fix an issue where emptying the rule list completely using the Remove button would not be immediately committed to the INI on save
(17) LogViewer: Add CTRL+X accelerator to clear log
(19) GUI.PriorityClassRulesDialog: Expanded width and other cosmetic
(19) GUI.ProBalanceExclusionsDialog: Fix handling of match strings with embedded commas
(19) GUI/Core: Refactor priority class rules, now supporting Regular Expressions
(21) GUI.ProBalanceExclusionsDialog: Cosmetic
(23) GUI: Add dark mode support to activation dialog
Process Lasso 12.0.1.6
v12.0.1.6 – Nov 23 2022
(5) GUI: Fix graph tooltip was vertically clipped with some system font scalings
(3) GUI: Fix tray icon wouldn't properly reflect CPU Utility % values exceeding 100%
(1) GUI: Add product version to user-agent string
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
Process Lasso 12.0.2.18
Changes in 12.0.2.18:
  • GUI: Improve control alignment in IdleSaver config dialog
  • GUI: Suppress INI parsing error messageboxes from Governor when running as a service
  • GUI: Show precise error message if Workstation key used on Server Edition
  • Build: Minor maintenance to build scripts
  • GUI: Add /activateonly command line parameter to ProcessLasso.exe to perform any deferred license activation from installer, then exit
  • GUI: Standardize /no_raise_existing command line parameter to /NoRaiseExisting
  • GUI/LogViewer: Replace filter edit control search and clear icons with shell stock icons
  • GUI: Refresh filtered view when process rules change
  • GUI: Expand width of edit controls in CPU affinity and CPU Sets dialogs
  • GUI: Right-align captions on edit controls in CPU Sets rules dialog
  • GUI: Change copyright years to 20
Process Lasso 12.0.3.16
February 3, 2023
  • (1) Installer: Improve EULA formatting
  • (1) GUI: Improve German splash screen text
  • (1) GUI: Show notification when Process Lasso starts with Keep Awake Indefinite still active
  • (1) GUI/Core: Allow Keep Awake Indefinite setting to persist across reboots
  • (1) GUI: Add registry option to disable Keep Awake Indefinite from persisting across reboots, HKLMSoftwareProcessLasso:KeepAwakeResetOnReboot (dword bool)
  • (7) GUI: Cosmetic to 'Main / Keep Awake' submenu
  • (9) GUI: Allow exit from beta channel while using a beta version, occurring upon the next update to a release version
  • (11) GUI: Translation updates
  • (13) GUI: Expand caption control widths (for longer languages) in dialogs: CPU Priorities, CPU Affinities, I/O Priorities, CPU Sets
