AlomWare Toolbox Beta
AlomWare Toolbox v9.0.0.1​
==== v9.0.0.1 (7 Sep 2026) =====
Bug fix: For validating a paid unlock code when the app is run at boot-up. Validation could fail if no internet connection was available when the app was launched.
Bug fix: For setting repeating reminders/tasks. You may need to delete and re-add them to fix (sorry!). This bug was overlooked when supporting other languages from v6.0.0.0.
Bug fix: Clicking arrived/missed reminders from earlier today would show "(Arrived|Missed )" in the Status Bar. Now it correctly says "([Arrived|Missed] today)" instead.
Bug fix: For saved window states being disabled by default when upgrading the app to v9.0.0.0 and later.
Bug fix: For the setting to auto-close these characters: ( { [ "
Enhancement: The "Image: Assign" step now accepts any text with a prefix of "qr=", and not just website URLs. There is a limitation of 2048 characters (2 KB).
Enhancement: The pop-up display for LED key states no longer briefly takes the focus away from your current window.
Maintenance: Other minor bug and stability fixes, code optimisations, and cosmetic text changes.
AlomWare Toolbox 9.0.0.4​
  • Enhancement: The "Files -> Backup" tab now lets you backup files up to 512 MB in size (up from 100 MB). 512 MB is the maximum file size of a Microsoft Word document.
  • Enhancement: Some invisible system windows were incorrectly being detected as visible for PC States and the Work Overview (such as "CrossDeviceResumeWindow" and "Windows Input Experience").
  • Enhancement: The app's update check is now almost instant when no update is available, because the change log is now only downloaded when an update is available.
  • Maintenance: Other minor bug and stability fixes, code optimisations, and cosmetic text changes.
AlomWare Toolbox 9.0.0.5​
===== v9.0.0.5 (18 Oct 2026) =====
Bug fix: Tweaked the way that clipboard monitoring works to follow the process recommended by MSDN (Microsoft's guidelines).
Bug fix: Taking a snapshot of a PC state will no longer play typewriter sounds during the snapshot when that tweak is enabled.
Enhancement: The "Make the Windows 'Run' box wider to show more text" tweak now also works with the "Run" box that is opened from the Task Manager (requires admin rights).
Enhancement: Some website URLs couldn't be copied when taking a screenshot because they override the browser's Ctrl+L hotkey. The app now falls back to Alt+D in such cases.
Enhancement: Added two more comparison options for action continuation tests: "item[!value" (item doesn't start with value), and "item!]value" (item doesn't end with value).
Addition: New automation step called "Toolbox: Show the magnifier", which shows or hides an on-screen magnifying glass for quickly zooming in on the desktop. Not intended to replace the "Misc" tab.
Addition: New variable called "tooldata$", which holds the directory of the app's "Toolbox Data" folder. An example use is shown here:
AlomWare Toolbox 9.0.0.6
===== v9.0.0.6 (11 Nov 2026) =====
Bug fix: For when the app's main hotkey is already taken by another app when Toolbox starts.
Bug fix: For the clipboard list not detecting new content in certain conditions.
Bug fix: For setting the backgound color for the "Mouse: Show the dock named" step.
Bug fix: Bulk file renaming would sometimes incorrectly report a name clash when none actually existed.
Bug fix: The "Computer: Move all windows" step could freeze the moved windows (making them non-responsive after moving).
Bug fix: If the desktop crashed, its data used by Toolbox was still incorrectly pointing to the crashed non-existent data.
Addition: New default action called "Computer\Macro record". Add it from the Action Wizard (the wand button) in the "Automation" tab.
Addition: New default action called "Computer\Macro play". Add it from the Action Wizard (the wand button) in the "Automation" tab.
Addition: New default action called "Computer\Show the magnifying glass". Add it from the Action Wizard (the wand button) in the "Automation" tab.
Addition: You can now click the Action list's "Trigger" header to filter actions by trigger type, such as to show only actions with hotkeys or typed text.
Addition: New PC tweak called "Middle-click the desktop to select the newest file on it". No longer hunt for that latest downloaded file in your desktop sea of icons!
Addition: New file rename mod: "Article order", so files starting with "A", "An" or "The" have these moved to the end after a comma (so "The African Queen" becomes "African Queen, The").
Enhancement: The "Folder Peek" function now works with folders on the desktop. Not sure why this was overlooked before. :(
Enhancement: The "Action Wizard" for creating expanded text from shortcut text has been redesigned to be more logical when creating them.
Enhancement: Text for the "string$" and "data$" variables can now have "{enter}" and "{tab}" included, which will use those keys where appropriate.
Enhancement: Actions triggered by a hotkey that use the "Keyboard" and "Macro" steps will now wait for the hotkey to be released so it doesn't affect those steps.
Enhancement: Disabled actions with a hotkey will no longer set the hotkey (and thus not show the "This action is currently disabled" message if the hotkey is pressed).
