Chasys Draw IES v4.75.01
Version 4.75.01
The following changes have been made to Chasys Draw IES with the latest release:
  • Canvas Resizing and Positioning for image and layers
  • Thumbnail mode in File Browser (Artist and Viewer)
  • Improved CPT file support (deprecated codecs)
  • Animations with hidden/excluded frames
  • Improved animation preview rendering
  • Improved Limit to 256 Colors effect
  • Improved Replace Color effect
  • UI palette import from image files
  • Improved plug-in error reporting
  • Improved Camera RAW file support
  • File Browser in Viewer can be docked left or right
  • Completely non-administrative Language management
  • Several minor improvements and optimizations
  • [bug fix] Incorrect PDF paper size recommendation
  • [bug fix] Palette names not updating
Pobieranie:
Chasys Draw IES 4.80.01
Chasys Draw IES 4.80.01 (11 Nov 2019):
  • Support for Canon CR3 RAW files (C-RAW)
  • Write support for paletted PNG files
  • Improved thumbnail rendering reliability
  • Limit Colors effect with configurable count
  • Improved XCF file support (XCF-10, GIMP 2.10.x)
  • Improved JPEG-2000 file support (update)
  • Improved graphics engine (JpDRAW2 18.11)
  • [bug fix] Scrollbar behaviour on high-DPI displays
  • [bug fix] Sporadic access violation errors
  • [bug fix] Some CPT layer names missing
Chasys Draw IES 5.00.01
Chasys Draw IES 5.00.01 (14 Apr 2020):
  • New and Improved User Interface
  • Major codebase rewrite and optimization
  • Borderless fullscreen with fade out in Viewer
  • Improved Previewer performance and timing
  • Smoother Object Animation rendering
  • Sprite-sheet manipulation features
  • Automatic EXIF rotation in Viewer
  • Improved Undo engine performance
  • Faster font loading and management
  • Pause and resume jobs in Converter
  • Save and JPEG auto-confirm for quick editing
  • [bug fix] Resource leaks leading to crashes
  • [bug fix] OS/2 style BMP files not loading
  • [bug fix] ICNS icon file loading errors
Chasys Draw IES 5.01.01
What's new in Chasys Draw IES 5.01.01
June 7, 2020
  • Additional codebase cleanup and optimization
  • Camera RAW now has a Color Histogram
  • Improved Bluetooth asynchronous transfers
  • Improved folder tracking in File Browser
  • Drives change monitoring in File Browser
  • Sorting options in File Browser
  • Workspace rotation by 180 degrees
  • [bug fix] Random crashes during autosave
  • [bug fix] Hand tool ignoring restrictions
Chasys Draw IES 5.02.01
Latest Changes
  • New completely rewritten animated GIF plug-in
  • Partial support for Affinity's AFPhoto files
  • Improved CPT file support (oversize images)
  • Square tip option for all tools
  • Separate
    and
    tools
  • New Effect:
    correction
  • Zoom option in previews for all effects
  • Image auditing and consistency checks
  • Improved preset handling (orientation, crop)
  • Improved Acquire/Scan functionality
  • Improved Web Browser Preview
  • [bug fix] Delayed preview rendering
  • [bug fix] Minor issues with small palettes
Chasys Draw IES 5.03.01
December 23, 2020
  • Sprite-sheet video support in Object Animation
  • Import Frame Animation into Object Animation
  • 3 new blending modes: Logical AND, OR and XOR
  • Side-by-side Comparison in Viewer
  • Pixel Grid at high zoom in Artist
  • Improved MegaStack™ plug-in
  • Improved Bluetooth OBEX
  • New Effect: Decolorize
  • Minor improvements for cropping and PDF export
  • [bug fix] Crashes caused by PCX plug-in
Chasys Draw IES 5.04.01
March 8, 2021
  • Full support for Affinity's AFPhoto files
  • Restrict modes are now Sprite-sheet-Aware
  • DPI calculation and update via Mark-up tool
  • Improved Object Animation preview rendering
  • Fast previews and thumbnails for Camera RAW files
  • Fast previews and thumbnails for Photoshop files
  • Fast previews and thumbnails for AFPhoto files
  • Fast previews and thumbnails for Krita files
  • [bug fix] OpenRaster compatibility with GIMP and Krita
  • [bug fix] Occasional flickering of Preview
Chasys Draw IES 5.05.01
May 6, 2021
  • Linked Layers (updated from external file)
  • New Tool: Animate (for easier object animation)
  • Improved Photoshop PSD file support (masks)
  • Improved Affinity AFPhoto file support (text layers)
  • Improved sprite-sheet support with dedicated metadata
  • Improved handling of DPI and hotspot information
  • Improved multi-monitor and triggering in Screen Capture
  • Auto-detect in Color Misalignment Correction
  • New Effect: Bayer Denoise
  • Improved Projection tool
  • Autosave compression
  • Full image flipping
  • Several UI improvements and minor fixes
Chasys Draw IES 5.06.01
Chasys Draw IES 5.06.01 (07 Jul 2021):
  • New Effect:
    (replaces Pinch)
  • New Effect:
    (replaces Swirl)
  • New Transform:
    (alternative to Swirl)
  • Zaloguj lub Zarejestruj się aby zobaczyć!
    with proxies for realtime previews
  • Auto-suggestion of image alignment reference points
  • Encode and Decode modes for
    rendering
  • Improved performance in MegaStack™ plug-in
  • Improved decoding of BMP and DDS files
  • Improved Krita KRA file support
  • Improved TIFF file support
  • Auto-detect in
  • GTX (Genetica and Group IV) file support
  • Support for Portable Float-Map (NetPBM/PFM)
  • Generation of merged data when writing PSD files
  • [bug fix] Missing checkmarks for options in Viewer
  • [bug fix] CD5 physical dimensions incorrectly set to PPM
Chasys Draw IES 5.07.01
August 16, 2021
  • Object Animation 3 with time shift
  • Timeline presets for common animations
  • Updated assets (Brushes and Textures)
  • Converter codebase updated and optimized
  • Simplified texture switching
  • Configurable WIA/TWAIN preference
  • [bug fix] Artist not restoring window position
  • [bug fix] One row offset when saving to DDS
  • [bug fix] Mark-up not updatable in Artist
Chasys Draw IES 5.08.01
September 21, 2021
  • New Adjustment: Color Balance
  • New Adjustment: Channel Mixer
  • Improved stability and reliability
  • Improved graphics engine (JpDRAW2 21.09)
  • Improved Toolbox user interface (style pop-up)
  • Improved Affinity AFPhoto support (adjustment layers)
  • Improved Adobe PSD support (more adjustment layers)
  • New video file plug-in (flt_Video, replaces flt_DShow)
  • Out-of-process video file loading via FastExternals
  • Improved JPEG-2000 and Motion JPEG-2000 decoding
  • Encoding support for Motion JPEG-2000 (.mj2)
  • Generation of merged image when writing ORA files
  • New shell icons for associated files
Chasys Draw IES 5.09.01​
October 29, 2021
  • New Adjustment: Exposure
  • New Color Picker mode: L*a*b*
  • Image normalization option in Viewer
  • Thumbnail normalization to improve visibility
  • Automated error reporting (optional)
  • Fast previews and thumbnails for Corel CPT files
  • Improved Affinity AFPhoto support (clipping, adjustments)
  • Motion Detection and triggering in Video Capture
  • Improved handling of removable drives in File Browser
  • [bug fix] Oilify effect corrupts colors
  • [bug fix] Pop-up close button not working
Chasys Draw IES 5.10.01​
December 18, 2021
  • Copy-paste for Layer Groups
  • Faster thumbnail rendering in File Browser
  • Improved shortcut key handling in Viewer
  • Auto-symbol extended with 16 new patterns
  • Improved handling of file associations
  • Shell integration for Microsoft Store version
  • [bug fix] Occasional Undo and Redo gremlins
  • [bug fix] Converter not including sub-folders
  • [bug fix] Installation failure on Windows XP
  • [bug fix] Microsoft Store version permission issues
  • [bug fix] Sprite-sheet to Animation frame-size
