Chasys Draw IES 5.12.01​
February 16, 2022
  • Highly parallel multi-process architecture for Converter
  • Support for up to 128 virtual CPUs in most modules
  • Lobby application to improve feature discoverability
  • Collapsible TextArt window with configurable defaults
  • Percentage option for layer transparency
  • Adjustment Layer masking option on attach
  • Improved image file loader efficiency
  • Several minor improvements and optimizations
  • [bug fix] Microsoft Store version Camera RAW issues
  • [bug fix] Incorrect Shell-out for Adjustment layers
  • [bug fix] Incorrect hotspot loaded for some cursors
  • [bug fix] UI font size issues on Windows XP
  • [bug fix] Language Studio edit-box errors
Chasys Draw IES 5.14.01​
March 15, 2022
  • New Tool: Content-Aware Eraser
  • Roughen and Spray-gun tools combined
  • Block and Decorative Gradients tools combined
  • Improved group paste functionality
  • Improved support for CPUs with more than 32 cores
  • Improved Viewer responsiveness in document folders
  • [bug-fix] Converter skipping sub-folders with one file
  • [bug-fix] Redo actions by Effects Plug-ins
Chasys Draw IES 5.15.01​
April 13, 2022
  • Converter refresh focusing on reliability
  • Content-Aware Background Fill
  • Content-Aware Transparency Cleaning
  • New Effect: Displace (for displacement maps)
  • Improved graphics engine (JpDRAW2™ v22.04)
  • Highly improved XBM and XPM file support
  • Improved Limit Colors effect (speed, options)
  • [bug-fix] Converter job ends prematurely
  • [bug-fix] GIF output mangled
Chasys Draw IES 5.16.01​
May 17, 2022
  • Updated Camera RAW file support
  • Linear RGB mapping option in Gradient Fill
  • Configurable high-performance NetPBM plug-in
  • Open in Google Maps option in Viewer
  • Configurable Animation Playback Speed in Preview
  • Palette name display, palette options in Objects
  • Improved handling of Linked Layers (multi-res)
  • Improved CD5 codec (v4.04, better compression)
  • Improved GPS EXIF handling
  • Improved Gradient Manager
Chasys Draw IES 5.17.05​
July 18, 2022
  • Animated PNG support (read and write, APNG)
  • Macintosh PICT support (read and write)
  • JPEG-XL support (read and write, static and animated)
  • Highly improved TGA (Truevision Targa) file support
  • Highly improved PCX and DCX (ZSoft) file support
  • Support for EXIF in PNG (both text and binary)
  • ICC profile handling for several file formats
  • Premultiply and Unmultiply Alpha effects
  • Improved Lab color handling in PSD files
  • Improved BMP and OS/2 BMP file support
  • Improved NetPBM file support
  • [bug-fix] Errors when saving .ANI
Chasys Draw IES 5.20.01​
October 5, 2022
  • Highly improved graphics engine (JpDRAW2 22.09)
  • New Effects-Brush tool option: Selective Recolor
  • New Dynamics tool option: Transparent Point
  • New Dynamics tool option: Opaque Point
  • Blocky Transforms for Pixel Art (No Resampling)
  • Click-and-drag selection in Screen Capture
  • Adaptive side-by-side panning in Viewer
  • Configurable CPU loading in Converter
  • Disk-full detection in Converter
  • Shell-out of embedded videos (sprite-sheets)
  • PDF import and improved PDF export
  • OpenEXR file support (read and write)
  • Quality Rollup: ANI file support
  • Quality Rollup: NetPBM file support
  • Quality Rollup: PhotoCD file support
  • Improved Bluetooth sharing support
  • Improved handling of EXIF orientation
  • Improved search function in Plug-in Manager
  • Improved CD5 codec (v4.06, better compression)
  • Several minor UI improvements
  • [bug-fix] Error loading some flat PSD files
  • [bug-fix] Installer does not install resources
Chasys Draw IES 5.21.01​
November 27, 2022
  • Fast JPEG read and write (up to 6 times faster)
  • QOI (Quite OK Image) file support (read and write)
  • Support for Cinepak-encoded Macintosh PICT files
  • Support for Corel-format Pattern files (.PAT)
  • Progress indication for loading and saving
  • File load and save cancellation via Esc key
  • Better handling of files with read-only support
  • Improved file association conflict detection
  • Caching of brush previews for faster rendering
  • Indication of power state for disk drives
  • [bug-fix] Optimized palette missing one color
  • [bug-fix] 16-bit PICT handling
  • [bug-fix] Some GIF glitches
Chasys Draw IES 5.22.01​
December 23, 2022
  • DPX (Digital Picture Exchange) file support (read and write)
  • Easier updates for plug-ins and language files
  • High responsiveness in Camera RAW
  • Improved Metadata Broadcast
  • Improved Video Capture reliability
  • Quality Rollup: Adobe ABR and PAT file support
  • Quality Rollup: DDS file support
  • Quality Rollup: ICNS file support
Chasys Draw IES 5.23.01​
January 23, 2023
  • New Layer Blend Mode: Behind
  • New Layer Blend Mode: Overpaint
  • Revamped Cloning Brush with blending modes
  • Improved operation logic/UX for Clone and Heal
  • Improved DDS file support (BC7)
  • [bug fix] Occasional/random crashes in Viewer
  • [bug fix] Zooming via +/- keys not working
  • [bug fix] PSD file memory errors
Chasys Draw IES 5.24.01​
Chasys Draw IES 5.24.01 (24 Feb 2023):
Chasys Draw IES 5.25.01​
Chasys Draw IES 5.25.01 (21 Apr 2023):
  • Quality Rollup focusing on stability and reliability
  • Improved
    (LLTE 2.01)
  • Improved
    performance (up to 2x faster)
  • Improved Copy-Paste interoperability with other apps
  • Improved DDS encoder output compatibility with other apps
  • JNG (JPEG Network Graphics)
    (read only)
  • MNG (Multiple-image Network Graphics) file support (read only)
  • TG1 (COKE Texture Format) file support (read only)
  • [bug fix] Random crashes when working with text
  • [bug fix]
    display issues
  • [bug fix] Endless loop focus stacking aligned images
Chasys Draw IES 5.26.01​
June 15, 2023
  • UI Color Themes including two Dark Modes
  • Revamped batch converter with a more user-friendly workflow
  • Mixed input in Converter (any combination of files and folders)
  • Improved video file decoding with hardware acceleration
  • Improved DDS file support (small-float formats)
  • Improved SVG file support (compressed SVG, GZip)
  • Improved EXIF handling (lens data and time zone)
Chasys Draw IES 5.27.01​
July 31, 2023
  • Native HEIF/AVIF file support (Microsoft HEIF not required)
  • Linked layers (Smart Objects) with customizable orientation
  • New UI Color Theme: Deep Sea (dark mode)
  • Zoom and Pan touch-screen gesture handling
  • Improved video import plug-in with frame scaling
  • Improved Krita KRA file support (oversize handling)
  • Improved Paint.NET PDN file support (oversize handling)
  • [bug fix] Ctrl+Z and other shortcuts trigger tool changes
Chasys Draw IES 5.28.01
hasys Draw IES 5.28.01 (25 Sep 2023):
