Chasys Draw IES 5.29.01​
Chasys Draw IES 5.29.01 (12 Dec 2023):
Chasys Draw IES 5.31.01
Jun 10, 2024
  • Quality Rollup for Q1 2024 focusing on third-party updates
  • Updated selection logic and anchor points (grab handles)
  • Configurable anchor points (grab handles) with 3 options
  • Support for ArtWeaver's native file format (.AWD)
  • Support for re-editable text in ArtWeaver AWD files
  • Improved Photoshop PSD file support (memory management)
  • Improved Pixlr PXZ file support (shape layers, flat image handling)
  • [bug fix] Perspective distort clips right edge of text
Chasys Draw IES 5.34.01​
Feb 3, 2025
  • Streaming Downsampler for host-based oversize handling
  • Landscape/portrait switch in Crop and Set Canvas
  • Improved TextArt rendering for oversized text
  • Improved PSD file support (multichannel and bilevel)
  • Improved PNG file support (oversize handling)
  • Improved JPEG-2000 file support (oversize handling)
  • Improved graphics engine (JpDRAW2™ v25.01)
  • Improved language translation engine (LLTE 2.02)
  • Several minor UI improvements
  • [bug-fix] Error reporting issues on Windows XP SP2
Chasys Draw IES 5.36.01
  • Change of name from “Chasys Draw IES” to “Chasys Photo”
  • Stereoscopic 3D with Anaglyph generation and preview
  • Color selection by name (name-to-color, pick-by-name)
  • Updated Shape tool (arrow) and anchor point logic
  • Line Tool and Curve Tool combined for better UX
  • Eraser Tool and Background Eraser Tool combined
  • Improved UIs for Layer Properties and Chroma Key
  • Support for Multi-Picture Object JPEG files (.MPO)
  • Support for Stereoscopic JPEG files (.JPS)
  • Support for Photoshop Large Document Format (.PSB)
  • Improved codec selection on Windows XP
  • Improved PDF file support (encryption, pages)
  • Improved MDP file support (compatibility)
  • Improved PSD file support (32-bit HDR)
  • [bug-fix] metadata missing in some BMP files
Chasys Draw IES 5.37.01​
  • AI Image Editing and AI Image Generation with API
  • Security Rollup for Q3 2025
  • Quality Rollup for Q3 2025 focusing on UI workflow
  • Send To Converter functionality in Windows Explorer
  • Improved graphics engine (JpDRAW2™ v25.11)
  • Improved animation rendering in Viewer
  • Improved EXIF handling (additional tags and unknowns)
  • Improved QR code rendering (small size handling)
  • Improved TWAIN scanning (reliability)
  • Support for Sun Raster image files (.RAS)
  • Support for CALS Raster image files (.CALS)
  • Support for Aldus Placeable Metafiles (.APM)
  • Support for Wireless Application Protocol Bitmaps (.WBMP)
  • Improved PSD file support (XMP, error handling)
  • Improved PDF file support (compatibility, encryption)
  • [bug-fix] Network Services may return truncated data
  • [bug-fix] JPEG failures on Windows XP
  • [bug-fix] Memory errors when saving to PDF
Chasys Photo (formerly Chasys Draw IES) 5.38.01​
  • Quality Rollup for Q4 2025 focusing on minor bugs
  • Configurable selection background for all tools
  • Improved graphics engine (JpDRAW2™ v25.12)
  • Improved JPEG-2000 file support (odd types)
  • Improved PDF file support (decoding logic)
  • [bug-fix] Tool guide/preview rendering errors
  • [bug-fix] Metadata loss when opening some old CD5 files
  • [bug-fix] Metadata loss affecting several file formats
Chasys Photo (formerly Chasys Draw IES) 5.40.01​
  • Brush Engine 5.01 with tool overlays for efficient rendering
  • Template-centric workflow for new project creation
  • Enhanced Hand tool that can perform basic actions
  • Print multiple copies per sheet (step and repeat)
  • Fuzzy layer selection logic for natural interaction
  • Independently rendered anchor points (grab handles)
  • Oversize palette support up to 1024 entries
  • Improved DPI handling with floating point math
  • Support for Windows Clipboard files (.CLP)
  • Support for Adobe ASE and ACO palette files
  • Improved PCX file support (EGA palettes)
  • Updated Camera RAW file support
  • [bug-fix] Frame conversion skips some frames
Chasys Photo (formerly Chasys Draw IES) 5.41.01​
  • Layered images with multiple pages (Composite/Multi-page)
  • Additional templates to support template-centric workflow
  • New Layer Blend Mode: Inverse Luma Mask
  • Improved CD5 codec (v4.10, improved ACSC compression)
  • Improved interpolation when downsizing images
  • Improved graphics engine (JpDRAW2� v26.05)
  • Improved motion detection in Video Capture
  • Cropping option when importing video
  • Slightly lower memory usage (RAM is getting expensive!)
  • Orientation options in QR Code Generator plug-in
  • Improved PXZ file support (placeholders, blanks)
  • Solved angle ambiguities (CCW versus CW)
  • Horizon detection in Rotate Transform
  • [bug-fix] Memory leak in flt_JPEG.dll
Chasys Photo (formerly Chasys Draw IES) 5.42.01​
  • User-friendly animation via Object Animation 2.0
  • Rotation, scaling and flipping support when animating
  • Import Object Animation as Sprite-sheet for embedding
  • Animated Linked Layers with Object Animation as source
  • Clockwise angles by default in all modules
  • Motion JPEG output expanded to both AVI and MOV
  • Support for old-style concatenated MJPEG files
  • Improved Animation Renderer plug-in
  • Improved CD5 codec (v4.11, object animation 2.0)
  • Improved graphics engine (JpDRAW2™ v26.07)
Chasys Photo 5.43.01​
Latest Changes (List)​
