FanControl v235​
  • Allow side-loading a different version of LibreHardwareMonitorLib placed in the Plugins folder
  • Trigger fan curve now has response time "up" and "down"
  • Trim serialization for json config files to make them smaller. WILL TRIGGER SAVE PROMPT, HIT SAVE
  • Tray icons nickname update bugfix\r\n- Update LibreHardwareMonitorLib
FanControl V238​
Migrated to the PawnIO version of LHM, Winring0 is no longer shipped with FanControl. This will prompt for the installation of the PawnIO driver. You may use the software without, but you won't get any motherboard sensors. Other sensor sources will still work as usual. This is a whole new driver implementation, it will contain bugs and require community efforts to iron them out. If you are happy with your current situation, I recommend you do not update for now.
