Monkey's Audio 10.13​
May 24, 2023
  • Fixed: The AVX-512 code could fail to compile on some systems.
  • Changed: Updated to Visual Studio 17.6.1.
  • Changed: Enabled reference optimization which makes the build smaller.
  • Changed: Updated to WavPack 5.6.4.
Monkey's Audio 10.18​
Version 10.18 (August 10, 2023)
  1. Changed: Switched to the
    to simplify inclusion of the source code.
  2. Changed: Renamed some macros from MAC_ to APE_ since APE is a little more widely used now.
  3. Changed: Updated to Visual Studio 17.7.0 (fixed code analysis warning about directories in the last builds).
  4. Changed: Updated the installer to NSIS 3.09.
  5. Changed: Updated to version 2.80 of the ALAC tool.
Monkey's Audio 10.20​
Version 10.20 (August 27, 2023)
  1. Changed: Added a License.txt file by the installer that gets copied to the install path (also included in the SDK).
  2. Changed: Updated to Visual Studio 17.7.2.
  3. Changed: Added a license link to the help menu.
  4. Changed: Changed a few variables to have APE_ names because JRiver was having compile problems (Objective C doesn't care that things are in a namespace).
