Monkey's Audio 10.25​
October 12, 2023
  • Changed: Made use of a new APE_INFO_MD5_MATCHES test during quick verify. This way reading the MD5 is wrapped up nicely.
  • Changed: Switched CAPEDecompress::GetInfo to a switch statement for slightly better performance.
  • Changed: Updated to Visual Studio 17.7.5
Monkey's Audio 10.26
  1. Changed: Updated to Visual Studio 17.7.6.
  2. Changed: Added a digital signature to the DirectShow filter.
  3. Changed: Added decoding support for version 4.11 files. There have been a couple reports of them. I don't know where they came from, but they verify using the latest code. Please share if you know about the origins.
Monkey's Audio 10.27​
November 16, 2023
  • Changed: APE tag details are reported for WavPack files when viewing file information.
  • NEW: When converting a WavPack file to APE, the APE tag is copied.
  • Changed: Updated to Visual Studio 17.8.0.
Monkey's Audio 10.33​
Version 10.33 (December 16, 2023)
  1. Changed: Made the program detect the incoming file type by reading the header instead of looking at the extension (makes W64 with WAV extensions work, etc.).
  2. Changed: Added support for files with the BW64 header.
Monkey's Audio 10.40
Version 10.40 (January 3, 2024)
  1. Fixed: The new header reader was not reporting position correctly so some files would fail to encode.
Version 10.39 (January 3, 2024)
  1. Changed: The list no longer updates when paused (it would flicker).
  2. Fixed: Compressing float files that were not marked as 32 bits per sample would not work properly.
  3. Fixed: WAV files that report chunk sizes that exceed the size of the file now fail with an invalid input file error.
  4. Thanks to Minseo Kim and DongEun Kim of the WHS WWW Team for their help finding and fixing these problems.
l
Podobne tematy:
