Monkey's Audio 10.84​
Dec 10, 2024
  • Fixed: When input data was from a pipe, it would still ask the file for the length which often returned 0 so the encode would fail. Now it returns a special value for pipes. Please report any issues.
l
Monkey's Audio 10.85​
  • Changed: Made readers no longer report pipes, but instead just flag it by returning an unknown length.
  • Changed: Made the non-Windows file reader report unknown length for pipes (should help pipes on other platforms).
l
Monkey's Audio 10.90​
Jan 19, 2025
  • Fixed: The toolbar could draw incorrectly when dragging between monitors.
  • Changed: Preventing drag off the screen of options uses the working rectangle instead of the monitor rectangle so the start menu can no longer be covered.
Monkey's Audio 11.00​
Mar 28, 2025
  • NEW: Added multi-threaded encoding and decoding (thanks Robert Kausch!) (uses the same setting for concurrent files but when processing less files than threads it will increase the number of threads -- so one big CUE file will be much faster).
  • Changed: Bumped the interface version because the number of threads was added.
  • NEW: When compressing from the command line, specify something like -threads=16 after the compression level to set the number of threads. (example: MAC.exe "C:1.wav" "C:1.ape" -c2000 -threads=16 -t "Artist=Abba")
  • NEW: When decompressing from the command line, specify something like -threads=16 after the decompress flag to set the number of threads. (example: MAC.exe "C:1.ape" "C:1.wav" -d -threads=16")
  • NEW: When verifying from the command line, specify something like -threads=16 after the verify flag to set the number of threads. (example: MAC.exe "C:1.ape" -v -threads=16")
  • Changed: Renewed the code signing certificate for another year.
  • Changed: Updated to Visual Studio 17.13.5.
  • Fixed: The installer made an extra entry in the uninstall section of the registry with the start menu folder but now it is with the other uninstall data.
  • Fixed: The path combobox did not allow entering a path longer than the combobox (it wasn't scrolling).
  • NEW: Added a thanks to Robert Kausch in the About box for all his genius (32-bit float, multi-threading, etc.).
  • Changed: Expanded the allowed number of simultaneous files to 32.
