Monkey's Audio 11.03​
  1. NEW: Added RVV SIMD support for machines with those instructions.
  2. Changed: Minor optimization to the AVX512 processing (thanks Robert Kausch!).
  3. Changed: Added runtime detection of NEON SIMD for ARM64EC builds.
Monkey's Audio 11.07​
Apr 10, 2025
  • Changed: Switched the projects to just use the latest installed v10 Windows SDK instead of a particular version.
  • Changed: Cleaned up the console mode parsing (please report any issues).
Monkey's Audio 11.09​
Version 11.09 (April 27, 2025)
  1. Fixed: Sorting a big list of files by size was not always working nicely.
  2. Fixed: Compressing files with a 0 size extra block in the WAV header could throw an error that the format was not supported (because the data was being read even though 0 bytes were reported).
  3. Fixed: The program could have problems when it freed the memory after compressing certain files because of an overrun.
Monkey's Audio 11.10​
May 3, 2025
  • NEW: Added support for running on big-endian CPUs (thanks Robert Kausch!).
  • NEW: Added AltiVec SIMD optimizations (thanks Robert Kausch!).
  • NEW: Added support for the FL32 data type in AIFF files.
  • Fixed: Fixed possible crash after decode errors.
Monkey's Audio 11.14​
Version 11.14 (May 22, 2025)
  1. Fixed: Decoding the last track from a CUE (as APL, etc.) could fail because getting the length of the last frame was looking at a tag size when there was no tag there.
  2. Fixed: Seeking at the start for CUE file playback could fail with the new threading.
  3. Changed: Updated to Visual Studio 17.14.2.
