Monkey's Audio 11.40
  1. Fixed: Reading from standard input could fail because it was wrapped with a header reader that didn't handle the number of bytes read properly.
  2. Changed: Renewed the code signing certificate for another year.
  3. Fixed: Some functions building without Unicode still had old names so the compile would fail.
  4. Changed: Renamed some variables to str_utfn from wchar_t to be more consistent with the APE naming.
Monkey's Audio 11.51
Version 11.51 (September 19, 2025)
  1. Fixed: Converting APE to APE of floating point files was not working properly.
  2. Changed: Switched the processing defaults so signed 8-bit and big endian processing no longer happen when passing NULL as the APE_GET_DATA_PROCESSING since they're normally not needed, but float processing still happens with NULL
Podobne tematy:
