Monkey's Audio 11.65​
  1. Changed: Updated to Visual Studio 2026 (11116.177).
  2. Changed: Removed a patch for 3.99 files that were converted from APE to APE and had the file tag as part of the WAV terminating data (it's been over twenty years).
  3. Changed: Updated the years to 2026.
  4. Changed: Various code cleanup changes (hopefully internal changes, but please report any issues).
Monkey's Audio 11.70​
  1. Changed: Added instructions for building MAC under Linux on Windows with WSL to the readme in the SDK.
  2. Changed: Added the VS2022 projects back because they could be needed by third-parties (like JRiver).
  3. Changed: Updated to Visual Studio 2026 (11123.170).
  4. Changed: Added GetFieldNumber to the IAPETag interface for retrieving numeric versions of fields.
  5. Changed: Renamed some of the old MACLib files to put Old in the names and removed a dash in another.
Monkey's Audio 11.81​
  1. Changed: Updated to Visual Studio 2026 (Version 11201.2).
  2. Changed: Issued the code signing certificate from Certum again (latest CardManager wasn't seeing cert so a bit of a worm-hole for a few days).
  3. Fixed: Corrected a place where the input source was being created and hadn't added the new boolean for reading the full input.
Monkey's Audio 11.83​
  • Fixed: Windows 7 compatibility was broken because using the new C runtimes requires Windows 8 or newer. Switched back to the VS2022 runtimes.
  • Changed: Updated to Visual Studio 2026 (Version 18.0.0).
  • Fixed: ID3v2 tags could read extra stuff at the end of strings if the tags were not NULL terminated.
Monkey's Audio 11.87​
Version 11.87 (November 21, 2025)
  1. Changed: Switched to the VS2022 runtimes so Windows 7 and 8 compatibility remain without a special build.
  2. Changed: Updated to Visual Studio 2026 (Version 18.0.1).
  3. Changed: Suppress unused command line arguments in the VS2026 projects because Microsoft said they may never fix the problem.
