Monkey's Audio 11.89​
  1. Changed: Revised comment parsing from ID3v2 tags so the second string in a comment no longer requires a NULL terminator (please report any issues).
  2. Changed: Updated to Visual Studio 2026 (Version 18.0.2).
  3. Changed: Removed the GDI bitmap pointer because now a simple CSmartPtr works (was just a Clang problem).
Monkey's Audio 12.00​
  1. Changed: Merged the DirectShow filter into MACDll (already used for Winamp, Cool Edit, etc.).
  2. Changed: Standardized the copyright string used on the webpage and in the program.
  3. Changed: Brought CGDIBitmapPtr back for VS2022 (VS2026 just does a regular delete in it).
  4. Changed: Check return values on FillBitArray(...) calls to check for read failures.
  5. Changed: Updated to Visual Studio 2026 (Version 18.2.0).
Monkey's Audio 12.01​
Version 12.01 (January 15, 2026)
  1. Fixed: When converting a big batch of files with the FLAC format the window of new processes could be incorrectly closed by finishing of other processes (maybe the name containing dashes was a problem) so the conversion did not succeed.
  2. Fixed: Circle buffer was not building on PowerPC because of a missing include.
Monkey's Audio 12.06​
  1. Changed: Compression was allocating two channels for mono files for no reason (please report any issues).
  2. Changed: Added a file APEThreads.h you can include that contains a macro for setting the number of threads for encode or decode using the CPU cores.
Monkey's Audio 12.08​
Version 12.08 (January 29, 2026)
  1. Changed: Updated CMakeLists.txt to work on systems that don't support pedantic warnings.
  2. Changed: Saved All.h as ANSI instead of UTF-8 (the copyright symbol should still work) because UTF-8 is not accepted by some compilers.
