Monkey's Audio 13.06​
Version 13.06 (June 18, 2026)
  1. Changed: Removed macros to convert int64 values to pointers and instead call discrete functions.
  2. Changed: Updated to Visual Studio 2026 18.7.1.
  3. Changed: Merged information gathering in the info and decompress object into a shared base class (IAPEInfo).
Monkey's Audio 13.10​
Version 13.10 (June 27, 2026)
  1. Changed: Removed the AVX instruction _mm256_zeroupper because it should be unneeded and it helps performance.
  2. Changed: Interim mode is only handled by the non-assembly code NNFilter (so it can be removed from the assembly routines) and it's better wrapped up.
  3. Changed: Updated to Visual Studio 2026 18.7.2.
  4. Changed: Switched to only APE::IAPEProgressCallback for progress callbacks so a context is always provided.
  5. Changed: Removed the kill flag since that's provided in the IAPEProgressCallback interface.
  6. Changed: Incremented the interface version for the progress changes.
  7. Changed: Provide CAPEProgressCallbackStaticFunction to call a static function with a context variable (void *) for progress.
  8. Changed: Faster implementation of CalculateDotProductAVX2 by unrolling 4x.
Version 13.07 (June 23, 2026)
  2. Changed: Faster implementation of CalculateDotProductAVX2 by unrolling 4x.
  3. Changed: Faster implementation of AdaptAVX2.
Monkey's Audio 13.12​
Monkey's Audio - a fast and powerful lossless audio compressor
Version 13.12 (June 27, 2026)
  1. Changed: Added a kill flag to the progress callback function.
  2. Changed: Removed CAPEProgressCallbackInfoStaticFunction (since callback info has a function now).
Monkey's Audio 13.17​
Version 13.17 (July 1, 2026)
  1. Changed: The version number of the program is written to the file (as well as the file version, which hasn't changed for a long time).
  2. Changed: Moved some more interim code into the interim header.
  3. Changed: Updated to Visual Studio 2026 18.7.3.
Monkey's Audio 13.18​
Version 13.18 (July 1, 2026)
  1. Changed: Made legacy (3.98 and earlier) files use the generic NNFilter so the version check when updating delta could be removed from the faster implementations.
  2. Changed: The version passed around everywhere is a structure that contains the version and flags (like interim).
Monkey's Audio 13.19​
Version 13.19 (July 20, 2026)
  1. Changed: Updated to Visual Studio 2026 18.8.0.
  2. Changed: Made the version object a class and included both the program and file version (used internally).
  3. Changed: Added a .clang-tidy configuration file to exclude the DirectShowSDK then turned Clang back on for MACDll.
  4. Changed: Visual Studio removed the XP compatible naming from the v141 (Visual Studio 2017) libraries, but using still and hopefully still working on XP (switched from v141_xp to v141) (feedback appreciated).
Monkey's Audio 13.20​
Version 13.20 (July 22, 2026)
  1. Changed: Switched to Visual Studio 2022 to build the 32-bit XP compatible version (because they still have XP support there).
  2. Changed: Updated to 2.89 for the ALAC tool.
  3. Changed: Turned on this switch for XP /Zc:threadSafeInit- because it was recommended.
  4. Changed: Cleaned up the process naming and cleanup now that the popup window is never shown (so there's no need to destroy lingering windows).
Monkey's Audio 13.21​
Version 13.21 (August 3, 2026)
  1. Changed: Updated to Visual Studio 2026 18.8.2.
  2. Changed: Added bugprone checks (minus a few specific ones) to Clang and worked through the warnings.
Monkey's Audio 13.22​
Version 13.22 (August 5, 2026)
  1. Changed: Installed the 2017 build tools then the XP runtimes could be selected in Visual Studio 2026, so it's being used for the 32-bit builds again.
Monkey's Audio 13.23​
Version 13.23 (August 8, 2026)
  1. Changed: Switched back to Visual Studio 2022 for the 32-bit build (XP is fully supported there and it's a wrench job in Visual Studio 2026).
  2. Changed: Reset the frame error states after a seek.
