- Dołączył
- 26 Maj 2010
- Posty
- 23324
- Reakcje/Polubienia
- 71586
Monkey's Audio 12.66
Pobieranie:Version 12.67 (April 16, 2026)
- Fixed: The 64-bit install would use the XP compile of MACDll.dll.
- Changed: Renewed the code signing certificate for another year.
- Changed: Updated to Visual Studio Insiders 11716.218.
Pobieramy na stronie:Version 12.71 (April 24, 2026)
- Changed: Switched to the latest Windows SDK (10.0.28000).
Pobieramy na stronie:Changed: Switched back to Visual Studio Community now that the fix is published (version 18.5.1).
- NEW: Data can be piped to the decoder (example 1: MAC.exe - C:\Out.wav -d < C:\In.ape | example 2: MAC.exe - - -d < C:\In.ape > C:\Out.wav)
- Changed: Modern common controls are called for in the manifest instead of in the code.
- Changed: When decoding from a pipe or other unknown length file, the entire input file is read to a buffer so the length can be properly calculated and seeks for each frame work properly.
Pobieramy na stronie:Changed: Switched to a FreeBSD MD5 implementation that's more compatible with the open source Monkey's Audio license.
Pobieramy na stronie:Changed: Corrected the Clang warnings with the new MD5 code.
Pobieramy na stronie:NEW: The font size selection is honored in all the menus by using custom drawn menus (Zaloguj lub Zarejestruj się aby zobaczyć!).
- Fixed: The menu while processing could be invalid in the last build.
- Changed: When closing while processing, a confirmation message is shown to make sure it was intended.
- Fixed: Menu navigation with the up and down arrow would stop at menu separators for the last few builds.
- Changed: Menus use a piece of art from the program instead of a system image for the checkmark (because then transparency works nicely).
Pobieranie:Version 12.84 (May 4, 2026)
- Fixed: Improved the menu drawing.
- Fixed: Menus wouldn't refresh when changing the font size in Options.
Pobieranie:Version 12.85 (May 5, 2026)
- Changed: Tuned the menu checkmark drawing to be higher quality.
