Monkey's Audio 12.86​
  • Changed: Removed extra checkmark state from the menu and preserve the checkmark when changing to owner draw.
  • Changed: Separators are now owner drawn in menus like all the other items.
Monkey's Audio 12.90​
  1. Fixed: Pressing ALT was not being handled nicely in the last build.
Version 12.89 (May 9, 2026)
  1. Fixed: The processing menu wasn't showing (with pause and stop) for the last few builds.
  2. Fixed: The file information dialog respects font sizes better.
Monkey's Audio 12.95​
Version 12.95 (May 18, 2026)
  1. Fixed: Flipping to the pause menu item while processing could lead to problems.
Version 12.94 (May 18, 2026)
  1. Changed: Clicking a menu item again will close the menu.
  2. Changed: Mousing over other menu items when one is open will open the other.
Monkey's Audio 12.97​
Monkey's Audio - a fast and powerful lossless audio compressor
Version 12.97 (May 20, 2026)
  1. Fixed: ALAC was not working since adding the UAC checks in 11.17.
  2. Changed: Updated to NSIS 3.12.
  3. Changed: Updated to QAAC 2.87.
Pobieranie:
Monkey's Audio 12.98​
Version 12.98 (May 25, 2026)
  1. Changed: Updated to Visual Studio 2026 18.6.1.
  2. Changed: Put decoding of 3.93 to 3.95 files in an APE_BACKWARDS_COMPATIBILITY block and moved the code to Old/NewPredictorOld.
  3. Fixed: One of the decoder initialization routines did not handle failures nicely.
Monkey's Audio 13.01​
  1. Changed: Updated to Visual Studio 2026 18.6.2.
  2. Changed: Minor internal code cleanup.
  3. Changed: Updated to 2.88 for the ALAC tool.
  4. Changed: When picking an external codec, the name (like WavPack) is listed on the toolbar button instead of "External".
Monkey's Audio 13.04​
  1. Changed: Worked the warnings away in the standard I/O object.
  2. Changed: Updated to Visual Studio 2026 18.7.0.
  3. Changed: The latest Clang doesn't specify default checks so commonly used ones were chosen and some more warnings worked through.
  4. Changed: Switched to simple inline instead of __forceinline for functions because the compiler should make good decisions.
Monkey's Audio 13.05​
Version 13.05 (June 15, 2026)
  1. Changed: Removed the option to show popup windows for external tools and just always hide. FLAC conversion would sometimes still leave stale windows and no other solution could be found.
  2. Changed: Switched the 32-bit WavPack executables to ones that will run under XP (like Monkey's Audio).
